Quick question. My phantom gimbal always moves to a angled downward position. I can use th dial on the remote to adjust/tilt the gimbal but i need to hold the wheel to keep it tilted. As soon as i let go of the dial it goes back to the default camera angle. Wondering if this is normal? I would have thought i ciuld set the angle with the dial and it would stay at that angle, like my phantom 4.
I think you are on BASIC mode (old controller without the tilt dial).
To fix: Phantom Assist > RC > nominate UPGRADE mode if you have the tilt dial on the left shoulder of the controller. Recalibrate the sticks and move the Tilt dial.
I know you're using the new RC controller but which gimbal are you using? If your using H3-2d the NDJ6 is simply not compatible.If you are using an aftermarket gimbal it's any body guess whether it will work correctly.
