Phantom 4 Pro + Editor Help
Has anyone used the Phantom 4 Pro + editor with the SD card from the aircraft? At the moment I have no other way to edit my flight files and cannot find any instructions anywhere as to how to use the Pro 4 + editor built into the Pro + controller. Any help would be greatly appreciated. Thanks
mine does not record to sd card from my remote ( internal )
The video footage is recorded onto the SD card while the card is in the aircraft. The card is then removed from the aircraft and inserted into the Phantom 4 Pro + remote controller (yes the + version has the built in screen on the RC). Allegedly you can then edit the footage using the editor built into the 4 Pro + remote control.
The issue is there are no instructions anywhere to be found as to how to use the editor.
Reactions: lone droner
brianklenhart
