Phantom 3 Standard range mod , let's do it together...
Ελα φιλε μου Απο θεσσαλονικη υπαρχει ειναι στην αθηνα τωρα ανοιξε λεγεται xlab
I ended up doing it this way and I'm getting 27dBm ... (this is my actual rcS from drone)
#!/bin/sh
# This script runs when init it run during the boot process.
# Mounts everything in the fstab
mount -o remount +w /
mount -t tmpfs mdev /dev
mkdir -p /dev/pts
mount -t devpts devpts /dev/pts
mount -t sysfs sysfs /sys
mount -t proc proc /proc
mount -t tmpfs tmpfs /tmp
echo /sbin/mdev > /proc/sys/kernel/hotplug
mdev -s
mknod /dev/caldata b 31 6
mount -t debugfs none /sys/kernel/debug
mkdir /var/run
mkdir /var/lock
mkdir /var/log
/sbin/klogd
/sbin/syslogd
insmod /lib/modules/3.10.49/compat.ko
insmod /lib/modules/3.10.49/crypto_blkcipher.ko
insmod /lib/modules/3.10.49/crc-ccitt.ko
insmod /lib/modules/3.10.49/arc4.ko
insmod /lib/modules/3.10.49/cfg80211.ko
insmod /lib/modules/3.10.49/mac80211.ko
insmod /lib/modules/3.10.49/ath.ko
country=`fw_printenv -n country`
if [ $country = "GB" ];then
fw_setenv country US
sleep 1
fi
insmod /lib/modules/3.10.49/ath9k_hw.ko cert_country=1
else
fi
insmod /lib/modules/3.10.49/ath9k_common.ko
insmod /lib/modules/3.10.49/ath9k.ko
echo dji > /proc/sys/kernel/hostname
/etc/init.d/sysfixtime boot
iw dev wlan0 del
#iw phy phy0 set antenna all all
iw phy phy0 set antenna_gain 0
iw phy phy0 set distance 0
iw phy phy0 interface add wlan0 type managed 4addr on
iw wlan0 set power_save off
ifconfig wlan0 up
brctl addbr br-lan
ifconfig br-lan 192.168.1.2 netmask 255.255.255.0 up
dwifi sta start
clisrv &
ifconfig usb0 hw ether 60:60:1f:ff:ff:ff up
brctl addif br-lan usb0
brctl addif br-lan wlan0
ifconfig lo 127.0.0.1 up
#telnetd -l /bin/ash &
mkdir -m 0755 -p /var/run/vsftpd
/usr/sbin/vsftpd &
#/usr/sbin/ntpd -n -p 0.openwrt.pool.ntp.org -p 1.openwrt.pool.ntp.org -p 2.openwrt.pool.ntp.org -p 3.openwrt.pool.ntp.org &
djiled.sh &
iw reg set US
iw phy phy0 set retry short 1 long 1
iw phy phy0 set rts off
iw phy phy0 set frag 256
iw dev wlan0 set noack_map 0x00c0
iw dev wlan0 set txpower fixed 2700
If you don't want go straigh to 27dBm, set 2000 instead in last line.
Make sure you make same changes to your remote too.
Remote is at 192.168.1.1
Drone is at 192.168.1.2
Do u hav the rcS files for the drone? I need a copy.
After further investigation, it seems your script missed a CRDA update, my drone remained on GB mode, 17dbm while the script was running...
I can provide you with the messages log if you want
Also, why don't we try a test on reg get result instead of looking inside logs for CRDA ? if reg get <> BO, then reg set BO => done !
I'm on expert on script though !
I posted my script to be improved by collective intelligence of talented people.
What I wanted to tell people was that I wanted to give those devices minimal burden, and checking modified time can be good method, instead of running iw everytime. You're free to improve and post back to this thread.
Someone has already told me the code needed. I think this is cleaner and more robust too now. Maybe
cmd=`iw reg get`
echo "$cmd" | grep "BO"
if [ $? -ne 0 ]
then
Looking this simple code, I feel some regret decided to use syslog to detect CRDA.
iqdba 's solution is guaranteed to work, good solution.
But I prefer making background script over using crond, because it is more used to me,
because once crond had me got a bad memory once personally...
Also if you're experienced on linux enough, you would notice that the code's style is not linux-like :)
ps. If you're plan to make script, I think grep would be robust than cut- and sed- then comparing equality.
It's possible that white spaces, newlines, messages, maybe different throughout many phantoms under all possible circumstances.
So not sure who this might help but I found that you can indeed force a downgrade on the Bird's firmware. Maybe this might help someone with a bricked bird.
Put FW 1.5 on your SD card, Press and hold the Sync button before turning the bird on. Turn the Bird on while still holding the Sync button for at least 10 seconds. You will here the usual FW upgrade beeps and the gimbal light will flash Red/Green. After about 10-15 mins, upgrade/downgrade will be completed and the gimbals light will stay Green and you will get a different beeping telling you that it has finished. Look at the contents of the SD card for proof.
(After 1.6.8 update) Phantom 3S Weak RC signal problem SOLVED!!!
Post #23 is where I did it.
========== 2014.01.01 00:00:14 remo-con disconnect======
Packet: P3C_FW_V01.05.0070.bin
Upgrading ...
Result: Success.
We should find a way to make a custom firmware which can be installed on the devices! Just got my drone today, experienced in Linux, bash scripting and loves programing. I'm going to dig deeper and see what other possibilities are available.
I update setchan.sh to version 1.1 for user who have external booster for his RC
#Version 1.1
# 1) Add new user argument
# -ch for set channel number, eg. -ch 13
# -booster will limit RC tx power to 20Dbm for protect your external booster
# 2) Add Restart udhcp and apsvr
setchan.sh
Hey, I can't access the file on google drive. The following message "Sorry, the file you have requested does not exist." is displayed. Could you upload this script to Build software better, together
Remove .zip extension. Check line ending before use (I opened it with sublime on osx, says file has unix line ending though)
Reactions: dadum01
Thanks :) Removed the .sh when copying it to the device and made it executable. It worked like a charm.
Excellent work OjczeNasz!
Anyone figured out how to use this method to P3P or P3A? There is no wifi, but there is USB. A year ago there was a legend about connecting to the telnet through USB, but nobody confirmed it.
Maybe for P3P and P3A we need just a driver and phantom will get IP (as phone and tethering) and we can 'get in' through the Telnet.
I think I will wait more till a specialist of you find a safer and easier way for ce users to make our signal stronger. Lots claimed bricked devices. Well done for research although
If your nifty with a soldering iron, I've published a PDF guide on how to unbrick them. You won't (can't) brick your device if you only edit djiled.sh though, if that makes you feel any more comfortable :)
Buy me one and I'll have a look ;-)
Saw your pdf . Nice work. What can I achive if I only edit djiled.sh?? 27dbm ?? Fcc instead of CE?? After soo many posts I think one should post a new and more complete step by step guide and the apps needed to complete .
Reactions: Davey B
djiled.sh *I believe* runs on startup, so you can get it to call your own .sh script containing the changes you want to make. I.e. FCC instead of CE, ch 13, 27dbm etc...
If I find the time over the next few days I'll put together another PDF for getting the thing to work in the first place :-)
Did a distance test yesterday and managed to get out to 1800m with stock antennae!
If I find the time over the next few days I'll put together another PDF for getting the thing to work in the first place :)
Are you ce user too? I have sent my drone to dji and I am waiting to receive it to install argtek 10dbi . I want to do this mod but I want a step by step guide to avoid bricking a new drone. Send it back after 5 days I bought it and I don't want to brick it . A new guide would be appreciated a lot :)
I am CE :)
