Need more info:
Why did you replace all 4 motors? To ensure they are all the same.
What was the "issue" you had with the one motor?Under lift the drone would rotate out of control. Single motor lagging behind
Did the other 3 motors work properly after the crash but before replacement?yes 3 were fine.
How hard was your crash? Was there fuselage/circuit damage?20m crash. Worked fine till the swap. Minor damage to shell
Can you provide pictures of the insides of your machine, including closeups of the motor solder connections and circuit boards?
Are you sure you replaced type for type? IOW, cw motors with cw, ccw with ccw? I replaced with the same yes
Is it possible you swapped out 2312 motors for 2312A or vice versa? Motors show 2312
Does your gimbal respond and sound its wakeup when you power up?Gimble works fine. Camera shows clear video.
What happens when you execute a CSC to turn the motors on? And I mean EXACTLY what happens. Nothing. App shows taking off, but motors show no reaction. No volts to motors
Does the DJI GO app tell you anything? You say there's no errors on the app, and that's a good thing, but does your P3 respond to any app commands?App shows no issue with the drone. No errors. No warnings. Take off on the app accepts the command but nothing else happens.
