Phantom 3 Pro/Adv error codes
PL
I've noticed there's no such list posted; the Dji Go app always explains what each code means, so it's not as important to have it; anyway, here it is:
error 1
Flight log said:
Compass error!
Dji Go said:
Compass Error. Restart Required. Contact DJI Support if this persists.
Amateur diagnose/fix said:
1. Switch off your drone, and start it again.
If issue persists:
2. Check cable between your compass and main board. Unplug it on both sides. Make sure the sockets are in good shape, not broken and not loose. Plug the cable in, moving it a few times in-out by a millimetre just before the fully plugged position.
If issue persists:
3. Try replacing the cable of the whole compass. If this doesn't fix the issue - problem must be in the main board or flight controller firmware.
If issue persists:
4. Contact support.
error 2
Flight log said:
Assistant protect!
Dji Go said:
error 3
Flight log said:
Device lock protect!
Dji Go said:
error 4
Flight log said:
Off radius limit landed
Dji Go said:
error 5
Flight log said:
IMU need adv-calib
Dji Go said:
IMU calibration required
error 6
Flight log said:
IMU SN ERROR
Dji Go said:
error 7
Flight log said:
temper not ready
Dji Go said:
Battery Temperature Too Low. Warm battery to at least 15 degrees Celsius before flying.
error 8
Flight log said:
Compass calibration!
Dji Go said:
Compass Calibration Required
1. Recalibrate compass in your drone.
If issue persists:
2. Move to a different area, away from any devices, power lines and steel or steel-reinforced ground or buildings. Remove any keys, rings, belt, watch, cellphone and any other devices or jewellery you have. Recalibrate compass.
If issue persists:
3. Get a magnet. Hold it a few centimetres from the compass in the landing pad, doing small circular moves on each side of the drone. Be careful - do not get the magnet too close, because you could permanently magnetize the compass, making it unusable. If you're not sure, try doing it further first, and go closer only if calibration still fails.
If issue persists:
4. Try a different compass (borrow or buy one). If new compass does not fix the issue - then the problem might be with main board or with firmware.
If issue persists:
5. Use product support.
error 9
Flight log said:
Attitude error!
Dji Go said:
error 10
Flight log said:
novice mode without gps!
Dji Go said:
Beginner Mode active. Wait until the GPS signal is stable before takeoff.
Wait for GPS signal; if nothing changes for 2-3 minutes, change the place to more open terrain, higher ground, or further from densely populated buildings. You may also just disable the beginner mode and fly without GPS.
error 11
Flight log said:
battery cell err stop motor!
Dji Go said:
Battery Cell Voltage Difference Error. Please contact DJI Support.
error 12
Flight log said:
battery communite err stop motor!
Dji Go said:
Battery Communication Error
error 13
Flight log said:
battery vol very low stop motor!
Dji Go said:
error 14
Flight log said:
battery user low land level stop motor!
Dji Go said:
error 15
Flight log said:
battery main vol low stop motor!
Dji Go said:
error 16
Flight log said:
battery temp and vol low stop motor!
Dji Go said:
error 17
Flight log said:
battery smart low land stop motor!
Dji Go said:
error 18
Flight log said:
battery bat not ready stop motor!
Dji Go said:
error 19
Flight log said:
may run simulator!
Dji Go said:
error 20
Flight log said:
gear pack mode!
Dji Go said:
error 21
Flight log said:
atti limit
Dji Go said:
error 22
Flight log said:
Product not activation,stop motor!
Dji Go said:
error 23
Flight log said:
in fly limit area ,need stop motor!
Dji Go said:
error 24
Flight log said:
bias limit
Dji Go said:
Sensor Bias Too Large. Place aircraft on a flat, level surface and perform IMU calibration.
error 25
Flight log said:
esc error!
Dji Go said:
ESC status error. Please restart the aircraft. Contact DJI Support if the error persists.
1. Switch off your drone, rotate each motor a bit, and start it again.
If issue persists:
2. Restart the drone again, squeezing one of the drone arms a bit. If the drone starts motors after such action, then there is a connection problem somewhere on the main board - it is dangerous to fly.
3. Connect the drone to a PC via USB, go into "flight log" mode and download flight logs. Use any of the tools to decode text messages from the last log. Check details about the ESC problem within the log, and which of 4 ESCs is causing it (ESC0...ESC3).
4. Open the aircraft and inspect visually the parts making up the ESC which number was mentioned in log. You can find the ESC by checking motor markings on the board - ESC0..ESC3 are mapped to M1..M4.
5. If you have enough soldering skill, you may try melting the connections and letting them re-solidify. Remember to use the proper flux/rosin.
If issue persists:
5. Replace the whole main board (or ask support to do it).
error 26
Flight log said:
IMU is initing!
Dji Go said:
IMU Warming Up. Wait before taking off.
error 27
Flight log said:
system upgrade,stop motor!
Dji Go said:
Aircraft is upgrading, please wait until the upgrade is complete.
error 28
Flight log said:
have run simulator, please restart
Dji Go said:
Flight Simulator is Running. Please restart the aircraft.
error 29
Flight log said:
be in cali!
Dji Go said:
Motor cannot run when IMU is calibrating.
error 30
Flight log said:
too large tilt angle when auto take off,stop motor!
Dji Go said:
Aircraft Tilt Too Large. Place on a flat, level surface and retry. Contact DJI Support if this continues after restart.
error 31
Flight log said:
gyro is stuck!
Dji Go said:
Gyroscope stuck. Please restart the aircraft. Contact DJI Support if the error persists.
error 32
Flight log said:
acc is stuck!
Dji Go said:
Accelerometer Stuck. Restart Aircraft. Contact DJI Support if this persists.
error 33
Flight log said:
compass is stuck!
Dji Go said:
Compass Stuck. Restart Aircraft. Contact DJI Support if this persists.
error 34
Flight log said:
press is stuck!
Dji Go said:
Barometer Stuck. Restart Aircraft. Contact DJI Support if this persists.
error 35
Flight log said:
press is negative!
Dji Go said:
Barometer Value is Negative. Restart Aircraft. Contact DJI Support if this persists.
error 36
Flight log said:
compass mod is huge!
Dji Go said:
Compass Mod Value Too Large. Restart Aircraft. Contact DJI Support if this persists.
error 37
Flight log said:
gyro bias is large!
Dji Go said:
Gyroscope Bias Value Too Large. Restart Aircraft. Contact DJI Support if this persists.
error 38
Flight log said:
acc bias is large!
Dji Go said:
Accelerometer Bias Too Large. Restart Aircraft. Contact DJI Support if this persists.
error 39
Flight log said:
compass noise is large!
Dji Go said:
Compass Noise Too High. Restart Aircraft. Contact DJI Support if this persists.
error 40
Flight log said:
press noise is large!
Dji Go said:
Barometer Noise Too High. Restart Aircraft. Contact DJI Support if this persists.
error 41
Flight log said:
sn invalid!
Dji Go said:
Invalid Serial Number
error 42
Flight log said:
press slope is large!
Dji Go said:
Barometer Error. Contact DJI Support if this continues after restart.
error 43
Flight log said:
ahrs error is large!
Dji Go said:
error 44
Flight log said:
flash operating!
Dji Go said:
FLASH Operating
error 45
Flight log said:
gps disconnect!
Dji Go said:
GPS Error. Contact DJI Support if this continues after restart.
error 46
Flight log said:
out of whitelist area!
Dji Go said:
That's all. I know it would be nice to have solutions linked for each issue, like in similar thread that exists for Phantom 1, but I don't have such knowledge.
Reactions: Greybush
Thanks quad, appreciate the reply.
Reactions: Greybush
