Phantom 3 gear (backpack, remote, batteries, etc.) Everything but the drone! $390
Selling a whole set of used gear for the Phantom 3 Professional--hardshell backpack, remote control, 3 batteries, 3 propeller sets, power adapter and other replacement pieces. It's everything but the drone (which I crashed into a river)! See the list below for descriptions and additional pictures via imgur links.
Selling as a complete package for $390 not including shipping from New Hampshire. Please let me know if you have any questions or want more detail/pictures. I cut and pasted this from my previous ebay ad which is why there's a lot of info here that most of you already know about the equipment. Cheers!
Phantom 3 Professional Remote Controller (GL300B)
Description: Used remote controller for Phantom 3, professional and advanced. 3.1 mile range. Battery: LiPo 6000mAh 7.4V. Left antenna screw became a bit loose last year so it's hot-glued into place (see photos), but when you adjust or fold the antenna it shows no signs of coming apart. There's a bit of grime on the phone/tablet holder (see photos again). Otherwise it works perfectly!
Photos:
Phantom 3 Hardshell Backpack
Description: Used. Water-resistant storage and transport solution with custom foam interior. Fits all the Phantom 3 drone models. Interior has an elastic strap to allow the holding of the aircraft securely, in place when in the horizontal position. However, you have to detach the props guards in the first place. It can accommodate the P3 quadcopter, remote controller, sets of propellers, the charger, and up to four Phantom 3 batteries; one in the phantom device and three in the dedicated battery compartments. Additionally, you can pack the radio transmitter an extra set of the propellers and other little accessories.
Photos:
Phantom 3 Intelligent Flight Battery x3
Description: Used. The new generation Intelligent Flight Battery is a 4480mAh, 15.2V LiPo4s battery that is specifically designed for the Phantom 3 series, enabling optimal performance. Supporting up to 23 minutes of flight time, the battery also has built-in sensors and bright LEDs that let you know the status and remaining power of your battery in real time.
Photos:
Phantom 3 Battery Power Adapter
Description: Used. ADE019 17.5V ~ 5.7A AC power adapter for charging intelligent flight batteries. For US outlets.
Photos:
Phantom 3 Self-Tightening Propeller, 2 pairs
Description: MINT. Compatible with all of Phantom 3 series. Self-tightening design, simply rotate the propellers by hand to attach or detach. Two pairs of two propellers each. Includes one clockwise replacement propeller and one counter-clockwise replacement propeller.
Photos:
Phantom 2 Vision Self-Tightening Propeller, 1 pair
Description: MINT. Compatible with all of Phantom 2 series. Self-tightening design, simply rotate the propellers by hand to attach or detach. Two pairs of two propellers each. Includes one clockwise replacement propeller and one counter-clockwise replacement propeller.
Photos: Imgur
SanDisk microSD to SD Memory Card Adapter X3:
Description: Used. Built-in write protection switch.
Photos: Imgur
Phantom 3 extra Vibration Dampers x4
Description: MINT. One extra set of four vibration dampers for Phantom 3 series. Used for connecting the camera mounting plate and the gimbal. Compatible with the Phantom 3 series.
Photos: Imgur
