Parts are TINY and would require microscopic soldering techniquesAny technical background why the old one can't be repaired?
Is that under warranty or without warranty???I checked with the RMA manager when I was at the repair facility.
They are doing what many shops are doing taking brand new P3's and parting them out and making double on them..
I replaced my board and checked it to see if flew and it did. However I also needed a couple of updates. After the udates is when I started getting this error. Sometimes it will start up but, more often will not and this error comes up...I'm wondering if it's more of a software glitch.Ugh.. I just sent my P3P in for the 2nd time. When I received it back from repair after a crash, it had the ESC status error. Didn't appear that they tested it before sending it back. Sounds like it will need a new motherboard based on this thread.
you can buy from dji for 129 usdi got couple main boards available too if anyone needs them. $350 without the motors or $450 with motors soldered on it
i have mine shipped to my brother in law in usa and here ships here to me in the philippinesyeah too bad it's not available in US![]()
Colleges, recently my Phantom 3 Pro had suffered the damage after hitting the tree and falling down from the height of about 4 meters.
After the crash "ESC status error appeared" on the DJI Pilot App.
Local service said that replacement of complete motherboard is required.
Well known is that P2 has separate ESC controllers that are exchangeable.
I'm wondering if motherboard here on P3 could be repaired on the component level i.e. replacing some electronic components, MCBs etc.
Lets try some technical discussion![]()
it's $269 on their site.Mine fell 20feet onto concrete. Several errors. It wouldn't even boot up. Soldered the black box back in place which completely broke loose and solved the data error by changing the SD card. Perfect now. Ordered online just in case I couldn't fix it.
Helidirect on eBay 149 ships worldwide. Just got mine for p3a
where did you find it for $149? unless it's used "as-is"
Would it make any sence buying P2 ESC PCB, comparing with the components of P3 "Part 33 ESC Center Board & MC" and further identifying/replacing faulty components.
