Phantom 2 to Phantom 3
Does anything from the Phantom 2 or Phantom 2 Vision + work with the P3 Standard? I mean like batteries, controller, props, landing gear, frame, etch. Thanks.
Just the micro usb cable, the prop removal tool, the white vibration dampeners and anti drop pins if you use them.
And don't even think about trying the props. They will fit but they will NOT work. P2 uses a metal hub and the P3 uses a composite rubber hub to prevent prop-off.
robvalduga
