- Joined
- Apr 3, 2016
- Messages
- 388
- Reaction score
- 123
- Age
- 68
I'll bet the friggin' gull didn't think so!Are you serious????
LMAO!!!
That's funny as hell.
LMAO!!!
You can manually switch flight modes at any point during your flight. If your Phantom is flying away because you calibrated the compass next to a large garbage truck (for example), changing the flight mode likely won't help you regain control of your Phantom.So when this so call flyaways happen, can you switch it to manual mode and take charge of the phantom?
You could if your Phantom flies beyond the range of Lightbridge and/or is in an area with a lot of interference.Do you lose lightbride?
hmm. Mine was a flyway. Nobody else can convince me of that. It happens, and I was one of the unlucky ones to have a defective product.
already did that in another thread.Upload the flight data
Without an explanation of what's happening in those videos and flight data it's not possible to work out what the incident was.One example of those doesnt discredit all the others. What conceivable user error could lead to a fly away like this:
or a bazillion others on youtube ?
Actual flyaways are much rarer than you would expect if you accept youtube accounts at face value.Yes, some of them arent fly aways and can be explained by user ignorance like the one you picked. That doesnt mean actual fly aways (out of control) dont happen or can be blamed on the user.
Since these so called flyaways are caused by a whole range of things (and almost all are related to the operation of the Phantom), no simple answer can be given to your question.So when this so call flyaways happen, can you switch it to manual mode and take charge of the phantom? Do you lose lightbridge?
When alleged P3 flyaways are investigated with flight data, it turns out that the majority are simply explained as flying behind obstacles or terrain, flying downwind in strong wind situations, not knowing how to activate RTH, not knowing that RTH has activated, bad compass calibrations, disorientation etc etc.
Get me a description of the incident and flight data and I'll investigate any incident.Im asking you to speculate. What possible user error could ever lead to such incidents and would be unavoidable even with proper flight control software?.
But I watched those videos and couldn't even understand what they thought the problem was from what I saw..
And since so many alleged incidents turn out to be operator error or confusion when investigated, that's the assumption I follow until some evidence is offered
And if you get a genuine malfunction, causing crazy uncommanded flight there's no amount of preparation or experience that will help you.I just picked two random examples on youtube, I can post these all day long. The bottom line is that it happens, and you better be prepared that it can happen to you.
Then you didn't notice anything.I noticed that. Just like I noticed you (incorrectly) assume the compass and GPS are immune to problems as long as you calibrate every flight. You have too much faith.
I'm sorry but I'm not sure what you're getting at or what you mean.As for the "genuine malfunction"; I put it to you that not even a hardware malfunction can plausibly explain these kinds of fly aways. A malfunction of primary flight sensors (gyro and accelerometer) would most likely cause your quad to wobble and flip like a madman, and crash in seconds. It would have to be some really freaky sensor malfunction that would allow it to maintain a level attitude and altitude, let alone pull off a controlled landing miles away. A hardware malfunction or environmental issue with the secondary, navigation sensors (compass and GPS) can and should be handled in a way that doesnt involve flying 3 miles away from its take off position.
If the Phantom gets conflicting information from the compass and GPS sensors, it will drop the GPS info and slip into atti mode.
Interference might cause you to lose signal which would trigger RTH but it would be most unlikely to have any affect on your compass or GPS.
It's much more likely that your incident was caused by a compass error, possibly caused by a bad calibration.
It's easy enough to look into the flight data and see what happened.
Go to https://www.phantomhelp.com/LogViewer/Upload/
Follow the instructions to upload your flight record.
Ok .. I've seen 3 cases of the P3 Standard resetting its home point and RTH sending the Phantom off to the new home point or complications due to having distance limit and the new home point being outside the distance limit.Lets recap; OP asked if he should be afraid of fly aways. You respond by saying its extremely unlikely and almost all reported incidents are caused by user error. I ask you to explain what user error could lead to an actual fly away, and I have not gotten an answer beyond stating that many reported fly aways are not truly fly aways, which is true. I can only conclude you agree with me that actual fly aways can never be blamed on user error, and yet they do happen. So the risk is real.
That's not just old - that's pre-P3.How big, is really hard to quantify, but I think you are seriously underestimating the problem. A few years ago, there was a poll on RCG:
RC Groups - View Poll Results
you'd hear most users that happened to be in the 66% lucky user group claim the product was just fine, and almost all fly aways where user error. I didnt buy it then, nor do I buy it now.
If you really think it may be 20% you have no idea.My TL : DR for the OP: yes you should be worried about the potential of a fly away thats not by your own doing. Over the life time of the drone, the risk may be 1% it may be 20%, no one knows for sure, but if you cant afford to lose the investment, dont buy one. And if you have more than an infinitesimal chance of hurting someone or something valuable if your drone goes out of control, dont fly there.
It's much, much less than 1%.
