P3A - GL300C - No Smartphone Connection
halo saya ada masalah controller phantom 3 pro akibat gagal downgrade firmware, firmware cloud pakai v1.9.3 dan waktu downgrade ke v1.9.2 gagal update firmware, kondisi controller saat ini , saat di hidupkan tidak berbunyi, warna lampu hijau keputihan, koneksi ke dji go masih terhubung tapi, saat memulai proses update, koneksi controller dan hp langsung putus... note: (menggunakan port usb yang hdmi)
mohon bantuannya saran dan masukannya sangat berharga, terima kasih.
Has anyone found a solution to bring the USB back to life on these controllers? I'm in the same situation with a gl300c and a gl300b, both for the phantom 3's. I've disassembled then and tested continuity of the data lines on the ribbon cable which turns out to be good, I think something has just gone wrong with the firmware.
