Naza won't recognise my pv2+?
Hi guys, No matter what I try my pv2 + simply won't connect to Naza M more mater how much I try. I keep hoping to see the blue light flash up at the bottom left of the screen but it never happens? I'd be very grateful for your help and ideas.
Thanks in advance.
Ps I'm running Windows 8
Clarksville Tn.
You need to disable driver signature enforcement. First hold down the shift key and restart computer. Once your computer has rebooted you'll be able to choose the troubleshoot option. Then head to the advanced options. Then start up settings. Disable driver signature enforcement. To choose the setting you will need to press F7. Once your computer starts back up you will have to manually install the driver. For some reason windows doesn't recognize DJI's drivers signature. Hope this helps. It work for me, and I had the same problem. Good luck.
schoolnetindia
