Oso
Premium Pilot
In the other threads that discuss props coming off, it seemed to happen when people do not snug up their props. Then when braking, the sudden decrease in motor rpm spins the prop right off. There was an epic thread in November with lots of analysis. If I recall correctly, people have even tested it to confirm it can happen.Not sure. But when someone says, "my prop(s) came off while flying", what else would cause a threaded prop to come off, especially since the motors spin in the opposite direction of the threads?
If the threads are indeed plastic, and heat generated from the motor causes the plastic to soften, and with enough resistance from the props cutting through air and torque from the spinning motors....wouldn't that cause threads to strip?
If someone has a bad prop, or one that they're willing to trash, they could tighten it and see how much it would take until it strips or breaks. Keep in mind, I'm also factoring heat from the motors.
