My drone just fell out of the sky
Discussion in 'Pro/Adv Discussion' started by Fatcat1, Feb 28, 2016.
  1. Fatcat1
    Texas
    Now I agree self tightening propellers my *** they came off and dropping down to the ground will post ppictures in about two hours
    Peter Unini Llacuna likes this.
  2. 185EZ
    #2 185EZ, Feb 28, 2016
  3. shorttimer
    Rocky Mountains
    "they came off"
    Are you saying they as in plural? Something obviously went wrong.
  4. Fatcat1
    Texas
    One did
  5. shorttimer
    Rocky Mountains
    Well if it is one that is a different story. That could be any and/or everything from a bad prop, putting it on wrong, motor froze up, ...
    Probably gonna have to look at your log files to see exactly what happened. Did you recover the missing prop? Was it an OEM DJI prop?
  6. RedHotPoker
    Edmonton Alberta
    Was it one of them triple bladed versions, you inquired about a few hours ago? That would be bad luck.
    RedHotPoker
  7. With The Birds
    Australia
    Please tell us it wasn't the fancy three bladed props...
  8. Fatcat1
    Texas
    No it wasn't one of the fancy three blades
  9. Fatcat1
    Texas
    Log says it was fine perfectly fine when I made it to turn to come back it was on his way back and then you see it's start going out-of-control crashed on the ground[​IMG][​IMG][​IMG]
  10. mrGREEK360
    How tight did you make the props? When the prop fell off, what were you doing in maneuves? Active braking from a fast speed?
  11. Fatcat1
    Texas
    Made a turn why?
  12. Mark The Droner
    It's my understanding that a P3 does not have self tightening props. That's a phrase left over from the P2 era.
  13. dsd317
    It's possible that your prop's threads stripped...especially if over-tightened. Were you able to retrieve the prop that came off? If yes, check the threads.
  14. Fatcat1
    Texas
    No didn't find it
  15. Fatcat1
    Texas
    But will check the threads on the actual motors
  16. dsd317
    I'm not 100% sure but I think the threads on the OEM props are softer than threads on motor so you may not find anything wrong with the threads on your motors. Best to find that prop for a more definite answer.
  17. Neary Aerial
    Florence, KY
    Hank Terrebrood likes this.
  18. Tim_alabim
    Is this kind of posting on multiple crash thread's really necessary, or appropriate?
  19. Fatcat1
    Texas
    Well sent it back to everon drone and they said it's a priority and we're just waiting for to come back and will take care of it we will see will keep my fellow drone pilots up-to-date on the situation
  20. CaptainDrone798
    Canada
    When you start you're Phantom 3 engines, it does two quick bursts of speed. The reason for this is to tighten the props.
    Obviously you can't expect the Phantom to tighten them perfectly which is why it's always best to tighten them yourself before starting the engines.
    So the Phantom does self tighten the props, but it's not perfect.
    snowghost, MrDroneUK and Ken Hanks like this.
Similar Threads - drone fell sky Forum Date
Drone fell outta the sky Photos and Video Aug 12, 2017
Drone fell out of sky... never happened before and I've had 4 of them Pro/Adv Discussion Jul 15, 2017
Drone fell from sky during RTH (Update - Replaced under warranty) Standard/4k Discussion Feb 19, 2017
Help, My Drone fell out of the sky, what can i do? Standard/4k Discussion Jan 17, 2017
Drone just fell out of the sky Pro/Adv Discussion Jun 23, 2016
