Is that Litchi app free or do they charge for it?
It's $15 for the basic app. If it really works (and people have done a LOT of testing), IMO it's worth it. I look forward to testing it out over the next week.
Pls ignore i rested the tablet reconnected to the pc and the dir reappearedUpdate the app to 2.3.0 and /dji.pilot directory is gone along with the hack. Pls advise?
It was because i unistaled and reinstated the app. ThanksI upgraded to 2.3 Android and my 32-channel file was still there and functional. Glad it worked for you too.
UK or Uganda does not mater which country u r you need to set your android tablet default settings to US and then it works.Has anyone in the UK ever go this channel hack to work on an Android device? I've followed the instructions and still can't access custom channels.
I've seen that you can change location on your Apple device but is there a similar workaround for Android?
It is the language that you have to change not the location. Change it to English (US) and you can see the Auto / custom.
So basically what i've noticed was that even if you do a 32 channel hack, it will show 32 channels in your app. However, if you pay attention you will see that your "current channel" will bounce only between 13-20 channel which makes me wonder of use of other channels. Aren't they redundant in this case?
Read the post 5 above yours...The problem is I can not select manual because it's grey and can not be chosen.
