Manually set X1 range.
Hello,
I have a Phantom2 with a H3-3D gimbal. Everything seems to work fine, except for the horizontal rotation of the gimbal, which I should be able to control using the lever on the back of my remote.
There's only a really tiny part in the lever's movement range that will change X1 correctly. Otherwise the camera is completely rotated down (X1=1000). Calibration doesn't change this.
At first I thought the potentiometer for X1 was faulty, but when measuring the resistance using a multimeter, it seems to work just fine.
Therefore I believe the calibration procedure doesn't work correctly and I was wondering if there is a way to set the range of X1 (the minimum and maximum values) manually?
Thanks!
You need to calibrate x1 in the RC assistant and then it do it again in the Phantom assistant.
robvalduga
