Litchi Keep Auto Landing
Has anyone experienced problems with litchi where without any confirmation the drone starts auto landing? My firmware is up to date as is the litchi app 3.10.10. Phantom 3 Standard, both with and without range extender. it has only occurred to me whilst in gps fpv mode, but it now has me nervous to do missions
Do you recall what the battery %/voltages were and were you flying with fully charged batteries at the time? I have read of auto landing at higher than expected voltages/% but there were issues with not flying with batteries that were either at or near 100%.
Try using the go app to see if you can replicate the auto landing to rule in or out any issues with Litchi.
Also make sure your setting for lost signal is set to return to home, and not land.
Check out your flight log to see if it explains what happened. You can upload and view it online here. If you'd like other people to review and comment on your flight log, then please post a link back here after you upload it.
Check out your TXT flight log to see if it explains what happened. You can upload and view it online here. If you'd like other people to review and comment on your flight log, then please post a link back here after you upload it.
So, where does Litchi have it's log file?
You can find them in the "flightlogs" folder on the device where Litchi is installed.
hi all, thanks for your help! my battery and my voltage were fine
the litchi is set to return to home not 'land'.
for some reason i think it would be because it may have dropped signal and started to auto land but just happened to be overhead that it started the landing mode rather then the return to home mode. the only odd thing is that it was well off the return to home point. i will get the log and upload.
the thing i mind most strange is that although it may have been a momentary lapse of signal i still had full video (aware its different) and still had full control.. standby for the logs
hcashmore11
