LB works with 2.4G channel for vehicle control AND video transmission.
The P2 radio is 2.4G but does not have a trainer plug.*
Thus the P2 radio cannot be used with LB due to interference.**, ***
When a non-2.4G radio is used, there are 2 options:
1. radio transmission is turned OFF on the radio and LB performs BOTH vehicle control and video.
2. radio transmission is kept ON on the radio and LB is used only for video.
* The trainer plug is required to send vehicle control input from the radio to the LB.
** The possibility of DJI developing an adapter to use the USB port on the P2 radio as a trainer is unclear.
*** The P2 radio's USB port can relay radio input information, but the transmission of 2.4G data through the radio's antenna must ALSO be turned off as it would interfere with the LB 2.4G band.
