Hi Papatita, I selected 27 dBm but didn't chose anything on optional setting. It works but it showed the following results. I had made these steps twice. Is that meant I have successfully changed to 27 dBm? Anything went wrong? Thanks for your help.
10:58 Log Filename: log201610170039.txt
10:58
10:58 ============================================
10:58 Restart your RC & Aircraft and Enjoy New Mod
10:58
10:58 Credit to: Ojcze Nasz, SingLag, Argonaise &
www.phantompilots.com
Disconnected.
Disconnecting.
10:57 wlan0 ESSID: "PHANTOM3_0b5bd9"
Access Point: 60:60:1F:01:02:03
Mode: Master Channel: 2 (2.417 GHz)
Tx-Power: 24 dBm Link Quality: 70/70
Signal: -35 dBm Noise: -95 dBm
Bit Rate: 101.1 MBit/s
Encryption: WPA2 PSK (CCMP)
Type: nl80211 HW Mode(s): 802.11abgn
Hardware: unknown [Generic MAC80211]
TX power offset: unknown
Frequency offset: unknown
Supports VAPs: yes PHY name: phy0
wlan0.sta1 ESSID: unknown
Access Point: 00:00:00:00:00:00
Mode: Master (VLAN) Channel: 2 (2.417 GHz)
Signal: -18 dBm Noise: -95 dBm
Bit Rate: 130.0 MBit/s
Encryption: none
10:57 iwinfo
10:57
BusyBox v1.22.1 (2015-11-16 16:28:58 CST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
/ # iw reg set BO
/ # iw dev wlan0 set txpower limit 2400
10:57 iwinfo
10:56 iw dev wlan0 set txpower limit 2400
10:56 iw reg set BO
Connected.
Connecting to 192.168.1.1.
Disconnected.
Disconnecting.
10:56 ==================
10:55 File upload OKE
10:55 Checking file ...
10:55 Update djiled.sh on Aircraft
10:55 Final process ...
10:55 hmod 775 /sbin/watchlog.sh
10:54 c
10:54
10:54 chmod 775 /sbin/watchlog.sh
Connected.
Connecting to 192.168.1.2.
Disconnected.
Disconnecting.
10:54 File upload OKE
10:54 Checking file ...
10:54 Update djiled.sh on RC
10:53 / #
10:53 Final process ...
10:53 hmod 775 /sbin/watchlog.sh
10:53 c
10:53 chmod 775 /sbin/watchlog.sh
10:52 wlan0 ESSID: "PHANTOM3_0b5bd9"
Tx-Power: 27 dBm Link Quality: 70/70
Signal: -33 dBm Noise: -95 dBm
Bit Rate: 57.7 MBit/s
Signal: -15 dBm Noise: -95 dBm
Bit Rate: 43.3 MBit/s
Encryption: none
10:52 winfo
10:52 i
10:52 iwinfo
10:51 BusyBox v1.22.1 (2015-11-16 16:28:58 CST) built-in shell (ash)
10:51 ==================
10:51 Telnet ready ...
Connected.
10:51 Aircraft Ready ...
10:51 RC Ready ...
10:49 File upload OKE
10:49 Checking file ...
10:49 Upload watchlog.sh to aircraft
10:48 File upload OKE
10:48 Checking file ...
10:48 Upload watchlog.sh to RC
10:47 File upload OKE
10:47 Checking file ...
10:47 Configure Telnet to Aircraft
10:46 File upload OKE
10:46 Checking file ...
10:46 Configure Telnet to RC
10:45 Aircraft Ready ...
10:45 RC Ready ...
Disconnected.
Disconnecting.
10:45 Select Menu: Patch with Magic Power
