How to Update Tx-Power with Magic Power v5.0
Sorry I created new thread to answer many questions about application windows DJIUpdate.exe, this app used to raise Tx-Power 2.4 GHz up to 27 dBm.
With new mod 2.4Ghz then video/live streaming so the better, minimize lag and unexpected effects became more far-reaching.
The application works with inject script (watchlog.sh) into the device and then run in djiled.sh
View attachment 62699 View attachment 62700
Additional features (DJIUpdate v3.6):
1. Unlock channel 13
2. Automatic Channel Scan (13-1)
4. Change Channel Manually (1-13)
5. Limit 20dBm (for user signal booster / amp).
6. Revert Back to CE (restore to default / Stock)
How to Update:
Change Channel Manually:
Download Application: P3S_27dBm_Updater.zip
** Specifically for the Phantom 3 Standard / 4K **
Technical discussions about how the mod please ask to existing topics: Phantom 3 Standard range mod , let's do it together...
Regards,
PapaTita
Mam przeogromna prosbe. Czy moglbys caly ten art. opisac w swoim ojczystym jezyku? :) Nie kazdy Polak zna angielski, a wiedza, ktora prezentujesz z pewnoscia przydalaby sie wielu z nas. Bardzo o to prosze :)
Dzięki za radę. Można użyć Google Translate przetłumaczyć na swój język
Sent from my Redmi Note 2 using PhantomPilots mobile app
Gonna bring my P3S back to the store the second time and ask for a refund....
Will go ahead for P3A instead..
Hi papatita.. Im using the stock antenna. Can I just use the 20dbm instead of 27?
Sent from my D6503 using PhantomPilots mobile app
You can use the option "FCC 20 dBm" (DJIUpdate v3.7), download link on the first post.
Hi Papa Tita.
Could you explain the difference between the two 20 dBm options?
[emoji2]
FCC 20 dBm and
RC limit to 20 dBm?
And also: is the default setting on the Standard 27 dBm for all FCC users? (FCC people that have not used the mod?)
Hi Papa Tita.
[emoji2]
FCC 20 dBm and
RC limit to 20 dBm?
Option "RC limit to 20 dBm", drone still 27 dBm.
"FCC 20 dBm" for rc and drone.
Default setting is 27 dBm. This has been the initial feature of app.
Reactions: toegema
Hello PapaTita,
Great tool you created ! Could you please update the first post with known working drone firmware based on p3S or p3 4k and same for dji app version ?
Regards,
Flo
Reactions: PapaTita
Papa Tita, My phantom 4k says firmware 1.5.40 can I use your program on it? Also this is the latest firmware or I can upgrade to a better version?
Thanks
Thanks
i use 4k and fw 1.5.4 too, this the latest fw, but i want to downgrade if found the link file. 1.5.4 just like 1.6.8 in p3s
Reactions: Johnny Mnemonic
Stupid question perhaps.. I did the upgrade on the RC. How to tell if it's on 27dB now? I'm using Android.
Stupid question.
It says to connect my laptop to the RC through wifi.
If I have a desktop with wired connection?
ps)My laptop is a macbook so this app cant be installed... :(
Stupid question.
It won't work with your desktop.
You can biy a cheap wireless usb key for the desktop.
Or install a windows vietual machine on the macbook pro.
Honestly 1 st solution is better, go for the usb wiffi donggle or the pci express wiffi card.
If i want to change 27db to 20db or 20db to 27db mod, do i need revert back to ce first.
adrie
