How can I connect my h3-3d to my computer? I dont see any usb ports...
Trying to use dji zenmuse assistant software
Why are you trying to connect the zenmuse to your computer? Which cannot be done. If you what to find out if the firmware is up to date then connect the P2 to the assistant software and go into upgrades tab.an if there is an update for the gimbal do it.
Then what is the zenmuse assistant for and how do i get it to work?
There is 2 H33D models - 'Phantom only' (printed on the box) model and GCU (gimbal control unit) model.
The Phantom model is for P2's. P2's have built in GCU's.
The GCU models are for non P2's and come with a The GCU is a module. These are people who build custom multirotors and wish to add a gimbal.
To distinguish them, the P2 models can be firmware resetted by shorting out 2 points on the mounting plate whereas the non P2 models need to be reflashed by the zenmuse software.
