- Joined
- May 21, 2020
- Messages
- 38
- Reaction score
- 10
- Age
- 49
I have seen nice strobe mounts that go on the legs but can’t find anything for mounting one on top.
How/where are y’all mounting yours on top? I was also concerned about interfering with any GPS antennas on top.
Thanks and be safe!
To clarify strobes are only useful for night flying correct? Who should consider buying this?
I use one of the very small 4 LED CREE strobes and I mount it on top of my P4P with velcro. I know it isn't going to accidentally dislodge because it is difficult to peel it off whenever I remove it. And I consistently connect to a minimum of 14 satellites with no GPS problems. The reason I use it during the day is to deter birds. I've had a couple of crows veer off course to check out my drone, only to flap as though startled when they got close and flew away. I have to believe the super bright strobe must mess with a bird's vision and throw them off because I usually have a difficult time, myself, just finding the off button because of flash spots in my eyes. So I generally recommend using strobes as a bird deterrent during daylight hours.
I don't mount ANYTHING on top....
A) GPS issues
B) If something comes loose way to close to props and since each one is a Single Failure Point I make sure to not add anything to that equation.
Several of our members and vendors off Phantom Strobe mounting options for the legs which is where, IMHO, they need to be mounted.
Where do you mount it on top of your P4? Thanks !
Smack in the middle. Doesn't interfere with my GPS, but I wouldn't mount anything larger. I found some clear velcro (hook side) that holds really well. The eye decals had been previously added also as a bird deterrent, since most birds that I have observed in nature prefer to attack from the rear and above -- mainly when their prey isn't looking at them. My work sometimes takes me to remote locations, so I need my drone to be as bird deterrent as possible. I agree the P4P has very limited locations to mount a strobe that doesn't interfere with the vision system.
I know someone is probably going to ask where I got the eye decals. I happen to be a graphic artist for an environmental firm (hence the drone flying) and had some clear peel-off sheets that can be put through a color copier/printer. I found those menacing hawk eyes via a Google image search, printed them on a peel-off sheet, and applied them as a decal to give my P4P a "Don't even THINK about it!" look.
Chorus
Private eyes
They're watching you
They see your every move
Private eyes
Private eyes
Watching you
Watching you
Watching you
Does it help? I mean by the reactions of birds when they see your drone.Smack in the middle. Doesn't interfere with my GPS, but I wouldn't mount anything larger. I found some clear velcro (hook side) that holds really well. The eye decals had been previously added also as a bird deterrent, since most birds that I have observed in nature prefer to attack from the rear and above -- mainly when their prey isn't looking at them. My work sometimes takes me to remote locations, so I need my drone to be as bird deterrent as possible. I agree the P4P has very limited locations to mount a strobe that doesn't interfere with the vision system.
Good point,,it be a 30 min staredown lol,,a slow circling staredown since they cant hoverDoes it help? I mean by the reactions of birds when they see your drone.
I mount mine on the top of the Parazero SafeAir system top cover. Neither interfere with GPS operation.Where do you mount it on top of your P4? Thanks !
I'm attaching my strobes to the legs using D-WINGS CORD CONTROL from Staples. These are designed to use as cord control. The strobe is glued to the flat side and then attached to the leg.
