Help!!!!?
Does the hero 3 work in the h4 3D gimbal in a FPV set up.
I've just bought a fpv kit and installed it to my phantom 2 with all the right parts but the transmitter is not picking anything up from the GoPro. I am currently using a the h4 3D gimbal but I've got the here 3 in it?????
It doesn't matter which gimbal you are using as both models are basically the same. How did you wire up the 5.8GHz transmitter did you hard wire it or used a plug n play cable?? You could have anyone of three problems a broken USB ribbon cable, bad 8 pin gimbal cable or you may shorted out the TX power supply. Or simply the camera, TX and monitor are incorrectly setup.
So lets start with the FPV kit you installed. Make and model of the TX, plug n play cable and monitor or monitor/receiver you are using would be of help in solving your problem.
