Help - tilt control not working
Discussion in 'Zenmuse H3-3D/H4-3D GoPro Gimbal' started by Ohary, Sep 6, 2014.
  1. Ohary
    I removed the gimbal from my P2 yesterday and also upgraded the NAZA software enabling IOC. But when I connected the Zenmuse the rear controller for tilt no longer works. Any help appreciated!
  2. Buckaye
    Orlando
    You can try the following:
    Go into the phantom assistant (not the controller one) with your phantom and controller on and then calibrate the X1 switch. You may have to move the switch multiple times to get the calibration right.
    I had something similar happen (it moved only a tiny bit) and once I calibrated the x1 it has been fine.
    Hope that helps
  3. Ohary
    Yes, apparently I was messing around with the calibration. Not sure what I did to fix it, but I entered calibration and it suddenly started to work.
    Unfortunately I was not able to find my FC40 I lost out in the woods.
Similar Threads - Help tilt control Forum Date
Tilt Control Help Phantom 2 Discussion Mar 29, 2014
Need Help with right tilted Gimbal on start up Pro/Adv Discussion Apr 14, 2017
I'm sorry but I need gimbal tilt help Phantom 4 Discussion Mar 1, 2017
Gimbal tilt - Only works occasionally on P2V+ (using Litchi for P2). Help! Phantom 2 Vision + Discussion Nov 5, 2016
H4-3D Tilt issue, need help!! Zenmuse H3-3D/H4-3D GoPro Gimbal Aug 11, 2015
