- Joined
- Sep 2, 2016
- Messages
- 262
- Reaction score
- 52
- Age
- 47
The first flight you posted shows you flying straight out until you lose signal at 4:40.1.
After 7.2 secs the video signal resturs at 4:47.4 with your Phantom already returning on the exact path to the home point.
The video shows that there was a slight pause as it turned but the Phantom never flew off in the wrong direction.
It appeared to act exactly as it is programmed.
Your second flight shows you flying out until you start to lose signal.
There are a number of breaks in signal at 8:01.5 (1.6 secs), 8:04.2 (7.7 secs) and 8:11.9 (26.2 secs).
When signal is restored at 8:38.1 your Phantom is in RTH and has flown 100 metres closer to the home point.
It is returning on the reverse of the course it was travelling when signal was lost.
At 8:53.5 it stops suddenly as the pitch indication shows.
At 9:03.04 it turns about 30 degrees while stopped and resumes flying toward home.
This appears to be doing exactly as it is programmed to.
On losing signal, it has retraced the path it was on and when it acquired signal, it has commenced a straight line RH to the home point.
I can't see anything to worry about and there's nothing DJI need to do.
Your Phantom behaved perfectly both times and never was in any danger of getting lost.
Yes Meta4, you're completely correct....
I'm sorry to misunderstand this behavior as an issue...
And for the O.P, i guess my case isn't exactly as yours... I wish you'll find the answer soon.
