Gl300a issue (p3p) not connecting to dji go
Hello,
It's m'y 1st post, i'm a New p3p owner [emoji16]
I just bought a p3p with an issue (i known that)
Actually:
-When i link the Ac to the RC, i have on both of them a green/red blinking led.
-When i connect my Phone, Nothing happen
-When i put a sd (on rc) Nothing happen.
-rc and Ac are linked because i can move the cam and take pictures.
-motors stay off
I'm on android, i tested several cables, original included. Tested several phones too (Xperia xz1, xa, z3, huwaei nova, lenovo tab 3 710)
Same for all.
I've tested my drone with a gl300c friend's RC and the P3P fly fine [emoji106] (no video on dji go but is an other problem which i'll try to solve later, When my rc will work)
I could checked the Ac fw version: 1.11.0020 (the Last in date)
So, my problem is a rc issue.
I don't know Its fw version...
No Connection with Phone... So i tried usb firmware update.
Tried 1.11.020 / 1.08 / 1.3.20 fw versions.
Nothing happen When i boot the rc.. (tried several usb flash drives & micro sd)
I tried to reset the rc to have the blue fixed led and re-pair to the Ac, unplug the battery from the rc's mainboard too.
Same....
Any idea what i can do more ?
What mean red/Green blinking on both parts ?
Thank you.
Hello,
Actually:
-motors stay off
Same for all.
Same....
Thank you.
It sounds like you have a defective RC (and possibly an issue with your top gimbal board which is common with the P3P) If the gl300c RC linked and worked fine (and started the motors) but gl300a RC wont then that indicates an RC issue, no connection to your device as well isn't good. The gl300c RC did obvs connect to your device and was flyable but no video feed which is a separate problem. Search "no live video P3P" for info on that. Good luck!
You mentioned an “sd”. Do you mean an sd card?
Yes!
-When i put a sd (on rc) Nothing happen. = Put a micro sd in an adapter to the RC usb port.
Why you think about that?
So,
If dji go doesn't detect my rc and if my rc doesn't detect any usb flash drive; It's dead for it ?
I tried to flash the usb board with usb-ttl card but i meet some issue in the procedure...
NB:I've already flash the gimbal main board and it works perfectly
But the difference between the two procedures is for the remote, as i understood, i have to decrypt the firmware before flash the board with it.
And this is for this point that i have a problem.
Maybe someone could help me for this flash?
Or maybe send me the decrypted .img files for GL300a?
Thank you
Did you update the FW on the RC?
When doing my latest FW update, I originally tried to update via the USB port on the RC. No bueno...I learned via Google and YouTube that the RC FW needs to be updated using the DJIGo app.
If you haven’t yet done this, give it a try.
Hope this helps!!
Hope this helps!!
Thank you WSCorp65; but as i said on my 1st post:
That's why i think the usb board have an issue and i would try to flash it.
I followed some threads:
I downloaded and try differents firmware:
C1_FW_V01.03.0020
C1_FW_v01.05.0071
C1_FW_v01.06.0001
when I try to decrypt using openssl, I get a "bad magic number"
In the boot sequence, i boot on the legacy kernel, not the main.
Code:
DM36x initialization passed!
UBL Product Vesion : DJI-GSP-UBL-1.0-rc10(2014-08-15)
Dji UBL Version: 1.51(Aug 15 2014 - 17:05:12)
Booting Catalog Boot Loader
BootMode = NAND
Starting NAND Copy...
Valid magicnum, 0xA1ACED66, found in block 0x00000019.
Uboot Checksum:0x7E25B44B
Actua Checksum:0x7E25B44B
U-Boot Product Vesion : DJI-GSP-Uboot-1.0-rc4(2014-07-23)
U-Boot 2010.12-rc2-svn-Dji (Jul 23 2014 - 11:14:40)
Cores: ARM 432 MHz
DDR:   297 MHz
I2C:   ready
DRAM:  128 MiB
NAND:  128 MiB
Bad block table found at page 65472, version 0x01
Bad block table found at page 65408, version 0x01
*** Warning - bad CRC, using default environment
Net:   Ethernet PHY: GENERIC @ 0xff
DaVinci-EMAC
Press ESC to abort autoboot in 1 seconds
Loading from nand0, offset 0x4a0000
** Unknown image type
Wrong Image Format for bootm command
ERROR: can't get kernel image!
Loading from nand0, offset 0x900000
   Image Name:   Linux-2.6.32.17-davinci1
   Created:      2015-02-12   3:09:59 UTC
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    3665856 Bytes = 3.5 MiB
   Load Address: 80008000
   Entry Point:  80008000
## Booting kernel from Legacy Image at 80700000 ...
   Loading Kernel Image ... OK
OK
Starting kernel ...
[    0.000000] Kernel Product Vesion : DJI-GRC-Kernel-1.0-rc8(2014-11-21)
[    0.000000] Linux version 2.6.32.17-davinci1 (u@dji) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-203) ) #1 PREEMPT Thu Feb 12 11:09:57 HKT 2015
[    0.000000] CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
[    0.000000] CPU: VIVT data cache, VIVT instruction cache
[    0.000000] Machine: DaVinci DM36x EVM
[    0.000000] Memory policy: ECC disabled, Data cache writeback
[    0.000000] DaVinci dm36x_rev1.2 variant 0x8
[    0.000000] Built 1 zonelists in Zone order, mobility grouping off.  Total pages: 12192
[    0.000000] Kernel command line: console=ttyS0,115200n8 rw dm365_imp.oper_mode=0 video=davincifb:vid0=0,10K:vid1=0,10K:osd0=1920x1080X16,8100K mem=48MB davinci_enc_mngr.ch0_output=COMPOSITE davinci_enc_mngr.ch0_mode=pal ubi.mtd=2,2048 root=ubi0:rootfs rootfstype=ubifs ip=off lpj=1077248
[    0.000000] PID hash table entries: 256 (order: -2, 1024 bytes)
[    0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[    0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Memory: 48MB = 48MB total
[    0.000000] Memory: 44836KB available (3304K code, 409K data, 108K init, 0K highmem)
[    0.000000] SLUB: Genslabs=11, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000] NR_IRQS:245
[    0.000000] Console: colour dummy device 80x30
[    0.000000] Calibrating delay loop (skipped) preset value.. 215.44 BogoMIPS (lpj=1077248)
[    0.000000] Mount-cache hash table entries: 512
[    0.000000] CPU: Testing write buffer coherency: ok
[    0.000000] DaVinci: 8 gpio irqs
[    0.000000] NET: Registered protocol family 16
[    0.080000] bio: create slab <bio-0> at 0
[    0.080000] SCSI subsystem initialized
[    0.090000] usbcore: registered new interface driver usbfs
[    0.090000] usbcore: registered new interface driver hub
[    0.090000] usbcore: registered new device driver usb
[    0.100000] cfg80211: Using static regulatory domain info
[    0.100000] cfg80211: Regulatory domain: US
[    0.100000]  (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[    0.100000]  (2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2700 mBm)
[    0.100000]  (5170000 KHz - 5190000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[    0.100000]  (5190000 KHz - 5210000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[    0.100000]  (5210000 KHz - 5230000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[    0.100000]  (5230000 KHz - 5330000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[    0.100000]  (5735000 KHz - 5835000 KHz @ 40000 KHz), (600 mBi, 3000 mBm)
[    0.100000] cfg80211: Calling CRDA for country: US
[    0.100000] Switching to clocksource timer0_1
[    0.110000] musb_hdrc: version 6.0, pio, host, debug=0
[    0.130000] musb_hdrc: USB Host mode controller at fec64000 using PIO, IRQ 12
[    0.130000] musb_hdrc musb_hdrc: MUSB HDRC host driver
[    0.130000] musb_hdrc musb_hdrc: new USB bus registered, assigned bus number 1
[    0.130000] usb usb1: configuration #1 chosen from 1 choice
[    0.130000] hub 1-0:1.0: USB hub found
[    0.130000] hub 1-0:1.0: 1 port detected
[    0.130000] NET: Registered protocol family 2
[    0.130000] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.130000] TCP established hash table entries: 2048 (order: 2, 16384 bytes)
[    0.130000] TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
[    0.130000] TCP: Hash tables configured (established 2048 bind 2048)
[    0.130000] TCP reno registered
[    0.130000] NET: Registered protocol family 1
[    0.130000] RPC: Registered udp transport module.
[    0.130000] RPC: Registered tcp transport module.
[    0.130000] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.140000] kfile init
[    0.140000] JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[    0.140000] msgmni has been set to 87
[    0.150000] alg: No test for stdrng (krng)
[    0.150000] io scheduler noop registered (default)
[    0.210000] Serial: 8250/16550 driver, 2 ports, IRQ sharing disabled
[    0.210000] serial8250.0: ttyS0 at MMIO 0x1c20000 (irq = 40) is a 16550A
[    0.580000] console [ttyS0] enabled
[    0.590000] serial8250.0: ttyS1 at MMIO 0x1d06000 (irq = 41) is a 16550A
[    0.600000] brd: module loaded
[    0.610000] NAND device: Manufacturer ID: 0x2c, Chip ID: 0xf1 (Micron NAND 128MiB 3,3V 8-bit)
[    0.620000] Creating 4 MTD partitions on "davinci_nand.0":
[    0.620000] 0x000000000000-0x0000004a0000 : "bootloader"
[    0.630000] 0x0000004a0000-0x000000e00000 : "kernel"
[    0.640000] 0x000000e00000-0x000007f00000 : "filesystem"
[    0.650000] 0x000000000000-0x000008000000 : "all"
[    0.660000] davinci_nand davinci_nand.0: controller rev. 2.3
[    0.660000] UBI: attaching mtd2 to ubi0
[    0.670000] UBI: physical eraseblock size:   131072 bytes (128 KiB)
[    0.680000] UBI: logical eraseblock size:    126976 bytes
[    0.680000] UBI: smallest flash I/O unit:    2048
[    0.690000] UBI: sub-page size:              512
[    0.690000] UBI: VID header offset:          2048 (aligned 2048)
[    0.700000] UBI: data offset:                4096
[    0.820000] usb 1-1: new high speed USB device using musb_hdrc and address 2
[    0.970000] usb 1-1: configuration #1 chosen from 1 choice
[    0.970000] hub 1-1:1.0: USB hub found
[    0.990000] hub 1-1:1.0: 2 ports detected
[    1.210000] UBI: attached mtd2 to ubi0
[    1.210000] UBI: MTD device name:            "filesystem"
[    1.220000] UBI: MTD device size:            113 MiB
[    1.230000] UBI: number of good PEBs:        904
[    1.230000] UBI: number of bad PEBs:         0
[    1.230000] UBI: max. allowed volumes:       128
[    1.240000] UBI: wear-leveling threshold:    4096
[    1.240000] UBI: number of internal volumes: 1
[    1.250000] UBI: number of user volumes:     1
[    1.250000] UBI: available PEBs:             0
[    1.260000] UBI: total number of reserved PEBs: 904
[    1.260000] UBI: number of PEBs reserved for bad PEB handling: 9
[    1.270000] UBI: max/mean erase counter: 113/2
[    1.270000] UBI: image sequence number: 865771820
[    1.280000] UBI: background thread "ubi_bgt0d" started, PID 272
[    1.290000] console [netcon0] enabled
[    1.290000] netconsole: network logging started
[    1.300000] Initializing USB Mass Storage driver...
[    1.300000] usbcore: registered new interface driver usb-storage
[    1.310000] USB Mass Storage support registered.
[    1.310000] usbcore: registered new interface driver usbtest
[    1.320000] i2c /dev entries driver
[    1.320000] watchdog watchdog: heartbeat 1 sec
[    1.330000] TCP cubic registered
[    1.330000] NET: Registered protocol family 17
[    1.340000] lib80211: common routines for IEEE802.11 drivers
[    1.340000] ksocket init
[    1.370000] encrypt device:atsha204 found
[    1.460000] mfi_i2c_client addr:17
[    1.470000] Clocks: disable unused vpss_master
[    1.470000] Clocks: disable unused mmcsd0
[    1.470000] Clocks: disable unused mmcsd1
[    1.470000] Clocks: disable unused spi0
[    1.470000] Clocks: disable unused spi1
[    1.470000] Clocks: disable unused spi2
[    1.470000] Clocks: disable unused spi3
[    1.470000] Clocks: disable unused spi4
[    1.470000] Clocks: disable unused pwm0
[    1.470000] Clocks: disable unused pwm1
[    1.470000] Clocks: disable unused pwm2
[    1.470000] Clocks: disable unused pwm3
[    1.470000] Clocks: disable unused timer1
[    1.470000] Clocks: disable unused timer3
[    1.470000] Clocks: disable unused emac
[    1.470000] Clocks: disable unused voice_codec
[    1.470000] Clocks: disable unused asp0
[    1.470000] Clocks: disable unused rto
[    1.470000] Clocks: disable unused mjcp
[    1.550000] davinci_emac_probe: using random MAC addr: 0e:26:17:00:93:9f
[    1.560000] emac-mii: probed
[    1.600000] UBIFS: recovery needed
[    1.660000] UBIFS: recovery completed
[    1.670000] UBIFS: mounted UBI device 0, volume 0, name "rootfs"
[    1.670000] UBIFS: file system size:   110342144 bytes (107756 KiB, 105 MiB, 869 LEBs)
[    1.680000] UBIFS: journal size:       9023488 bytes (8812 KiB, 8 MiB, 72 LEBs)
[    1.690000] UBIFS: media format:       w4/r0 (latest is w4/r0)
[    1.690000] UBIFS: default compressor: lzo
[    1.700000] UBIFS: reserved for root:  0 bytes (0 KiB)
[    1.700000] VFS: Mounted root (ubifs filesystem) on device 0:13.
[    1.710000] Freeing init memory: 108K
Filesystem Product Vesion : DJI-Filesystem-1.0-rc2
Runing /etc/init.d/rcS
[    3.450000] CMEMK module: built on Jul 30 2014 at 10:21:45
[    3.470000]   Reference Linux version 2.6.32
[    3.470000]   File /home/u/work/svn/dec_grc/src/dvsdk/dvsdk_dm368_4_02_00_06/linuxutils_2_26_01_02/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.c
[    3.490000] allocated heap buffer 0xc7000000 of size 0x4400000
[    3.520000] heap fallback enabled - will try heap if pool buffer is not available
[    3.520000] CMEM Range Overlaps Kernel Physical - allowing overlap
[    3.540000] CMEM phys_start (0x1000) overlaps kernel (0x80000000 -> 0x83000000)
[    3.540000] cmemk initialized
[    3.570000] IRQK module: built on Jul 30 2014 at 10:21:09
[    3.590000]   Reference Linux version 2.6.32
[    3.590000]   File /home/u/work/svn/dec_grc/src/dvsdk/dvsdk_dm368_4_02_00_06/linuxutils_2_26_01_02/packages/ti/sdo/linuxutils/irq/src/module/irqk.c
[    3.610000] irqk initialized
[    3.660000] EDMAK module: built on Jul 30 2014 at 10:19:34
[    3.680000]   Reference Linux version 2.6.32
[    3.680000]   File /home/u/work/svn/dec_grc/src/dvsdk/dvsdk_dm368_4_02_00_06/linuxutils_2_26_01_02/packages/ti/sdo/linuxutils/edma/src/module/edmak.c
[    3.900000] exFAT: Version 1.2.9
settime failed
* daemon not running. starting it now on port 5037 *
* daemon started successfully *
[   11.520000] usbcore: registered new interface driver usb_applehid
[   11.550000] usb applehid module init ok
[   11.580000] usbcore: registered new interface driver usb_68013
[   11.610000] usb 68013 module init ok
sulogin: no password entry for root
login[407]: root login on 'ttyS0'
#Process /etc/profile...
root@Dji-Pro:~# encrypt check ok
init  libusb successed!!!
usbmuxd disabled
usbsocket_init OK
usbsocket_create_handle ok, port:22345, bCanRecv:1
usbsocket_create_handle ok, port:22346, bCanRecv:0
watchdog timeout:5
DummyRead68013 0.000000kb
umount: can't umount /mnt/usb: No such file or directory
rmdir: '/mnt/usb': No such file or directory
encrypt chip exist
Interesting coincidence.. I'm just collaborating with @oemgpsnav to create a guide of fixing the flash on GL300a Interface Board.
Not sure when it will be published, but probably within 2 weeks.
I am planning to attach already extracted images to the guide.
? Cool!
I'm ready to test it! :)
