arizeda said:Don't apologise to me, I was just trying to help. Good luck
Thanks...really appreciate the help. Once I hit the submit button, I stepped away.
arizeda said:ddublu said:3.6 on a Mac. Flashing H3-3D IMU.
just an idea, but try an older version of the assistant, or a windows machine/virtual machine if you have access to one.
ddublu said:arizeda said:ddublu said:3.6 on a Mac. Flashing H3-3D IMU.
Well, just got new one and it works BUT it still starts up in straight down position. ARGH!
arizeda said:Hahaha ****.... Well in that case it could be many diff things... Your transmitter, receiver, flight controller... Calibration... Hmmmm
ddublu said:arizeda said:Hahaha ****.... Well in that case it could be many diff things... Your transmitter, receiver, flight controller... Calibration... Hmmmm
Can try a windows machine shortly but after yesterday not sure I am willing to do a factory reset on it. What should I do?
arizeda said:I don't know... Maybe best to compare your X1 behavior with someone. Like startup position etc. I can probably help on the weekend to compare
ddublu said:Anyone else have any suggestions?
spudraleigh said:ddublu said:Anyone else have any suggestions?
I have two P2's, a V1 and a V2. The V1 always starts with the cam facing straight ahead. My V2 "out of the box" started with the camera at a 45 degree angle. Odd... Anyway, as I went trying to correct it (BTW, it came with ALL newest firmware, etc) I noticed that when I used the Phantom Assistant, the behavior of the gimbal, now using the new controller, changed. I re-calibrated the X1 and X2 a couple of times, restarted the Phantom and the camera started facing straight ahead. No idea why this happened as the re-calibration should really not have had that affect but it did. So what I'm really saying is try everything (multiple times) no matter how silly or unrelated it might be and take note of each change in case you find an answer. Sorry, but that is the best I can do :?
This may be your problem, but it was not the OP's problem. His was a firmware issue that has been fixed.d4ddyo said:I just received my P2 H3-3D today. I found out the problem why it get's stuck in the horizontal position.
The bottom lip where the GoPro bracket screws in get's stuck on the gimbal. You can free it by hand. It still can get stuck if you put it horizontal during flight.
This happens because it cycles through and gets stuck in horizontal position.
Damon said:This may be your problem, but it was not the OP's problem. His was a firmware issue that has been fixed.d4ddyo said:I just received my P2 H3-3D today. I found out the problem why it get's stuck in the horizontal position.
ddublu said:d4ddyo said:I just received my P2 H3-3D today. I found out the problem why it get's stuck in the horizontal position.
This is not the case for me. It never got stuck as in hampered by something physical in its way.
arizeda said:Ddublu - managed to get my hero 4 now, assembled my gimbal on my phantom 2 v2, and it also starts in the down position![]()
ddublu said:arizeda said:Ddublu - managed to get my hero 4 now, assembled my gimbal on my phantom 2 v2, and it also starts in the down position![]()
I have the Hero 4 as well but do not feel it's related to which version of GoPro is in the gimbal. HAS to be software related.
d4ddyo said:yes. calibrate in RC assistant first including the x1. then go do the same in the P2 assistant.
Apparently they came out with a new RC assistant today.
