They phrase it a little differently here:
http://www.rcgroups.com/forums/showpost.php?p=28238271&postcount=10888
"Important firmware upgrade:
Recently, we have received many reporting cases that Phantom shakes violently when descending or even crash. Now the reason of this has been found.
When the aircraft is landing rapidly, due to its high speed, propellers will flow into the disturbed flow zone below, so the propellers will lose some power, and in this case users usually try to push the throttle to fly up, but in the meantime the aircraft will continue to fall because of its inertia, and this will lead to more power lost, so there will be not enough power to fly up or even maintain its attitude. In this case, the aircraft will be shaking a lot. And if the battery is low, the propellers' power will be even lower, which will definitely cause this problem.
The new v3.02 firmware has controlled the descending speed to 2m/s, in order to avoid propellers flow into the disturbed flow zone.
We strongly recommend that all users upgrade to the latest firmware as soon as possible, to avoid any crash or danger."
