- Joined
- Aug 31, 2017
- Messages
- 2
- Reaction score
- 0
- Age
- 74
Thanks. I must have misplaced that cable. Once they are connected are you still able to follow the upgrade progress on the screen? I believe you can only connect one or the other.If it is similar to the P4, I have a small cable supplied with the drone for exactly that. Connect your device and use the supplied USB cable to connect to the drone.
You would have to follow the P4P FW process which might be different to my P4. I upgraded my RC first through the app and the upgraded the drone through Assistant 2.Thanks. I must have misplaced that cable. Once they are connected are you still able to follow the upgrade progress on the screen? I believe you can only connect one or the other.
