P2V+ Firmware P4P+V2
Hi guys
Tomorrow I'm getting a relatively "unused" P4P+V2, sticker still on the aircraft.
I know that serial numbers should be GL300K for the remote and WM331S on the aircraft.
What are the latest firmware for the aircraft and anything special I should look for except that it starts?
Does batteries from a P4 advanced+ play with the V2 version?
Regards
Terraplane
Reactions: RodPad
Welcome to the forum!
Don't mess with the firmware until you make sure everything is good.
I'm sure all P4 are the same,
If I'm incorrect, somebody will reply
What is your experience with flying things in the air with out a string. :)
You should take a look at @msinger help.
Rod ..
The V2 was claimed to have a slight yaw issue as I remember. DJI, after some length of time did attempt to resolve that issue with a firmware update. Based on my experience, that firmware update did make a difference.
The P4 series batteries are all interchangeable between aircraft versions. There are two different capacities is the only difference. The V2 does have the ability to verify that the battery is in the correct position.
Reading material.
Reactions: RodPad
Thanks for the info, just picked upp my V2, looks brand new :) with papers and everything.
It wants network to sign in, but I don't find network options from startscreen?
Reactions: RodPad
