P3 Firmware Firmware Conundrum
I am working on 5, P3P's that I bought used, not working or crashed. 1 of these #5 is being rebuild with another top and bottom base, the AC was all cracked up and #5 RC has top case broken beyond repair, still looking for a used one.
The other 4, I checked the firmware numbers and came up with this.
DJI GO app...3.1.80
AC #1 P3P through AC #4 P3P are...1.11.20
RC #1 Controller.. 1.9.2
RC #2 Controller.. 1.9.2
RC #3 Controller.. 1.9.3 ***
RC #4 Controller.. 1.9.2
There is also this number below each of the above numbers, 01.00.01.09
The Controllers and Remotes all link-up no problem, all have the compass calibrated except #1. I will have to take it outside soon and try to calibrate it.
Do I need to update any of this firmware for the AC's or the RC's.
"If it ain't broke, don't fix it" applies to firmware updates. They usually cause more problems than they fix so avoid unless absolutely necessary..even if app requests it or says one available.
Reactions: captainmilehigh
BTIPP88
