dynamic home point
has anyone used the dynamic home point to function as a follow me work around?
Thanks Ken
It should work if the S2 switch is in Home Lock (bottom position) and you keep at least 32+ feet between you and your Phantom.
forgot to mention putting the S2 in Home Lock in NAZA. Il give it a shot and see what orientation it keeps. This thing is so cool...
Just make sure the GPS is activated on your FPV SmartPhone/Device and locked.
And make sure the Radar ring is GREEN and NOT orange/yellow.
Check the Ground station and make sure the H moves when your FPV device moves.
It pings every 2 seconds. If it doesn't, then DHP will not work properly.
And as stated, make sure you are 10m away from otherwise it will switch to course lock mode.
It's a function that Kenargo is building into his DJI ultimate app at present, search the forum for his thread on it
That only works on Android though :(
Welcome to "The Darkside"..... :twisted:
"And make sure the Radar ring is GREEN and NOT orange/yellow." how do you do that?? i use NAZA node and have an iphone and have enabled dynamic home point in vision app and i am more than 10m away from phantom but still nothing.. what am i missing?
Try this.
Enable GPS and data on your phone.
Start the DJI app and go into GS and download the maps.
Once done your phone should have a fix.
Now connect to the phantoms wifi and go through your normal launch sequence.
Once launched, go further than 10m and switch to GS and see if your device is dynamically changing positions. The ring should now turn green.
