dynamic home point
Discussion in 'Phantom 2 Vision + Discussion' started by Kbboehm, Feb 15, 2015.
  1. Kbboehm
    has anyone used the dynamic home point to function as a follow me work around?
    Thanks Ken
  2. Badger55
    Snowed in, in Connecticut
    Not sure that would work, I would assume that it would try and land.
  3. msinger
    Approved Vendor
    Harrisburg, PA (US)
    It should work if the S2 switch is in Home Lock (bottom position) and you keep at least 32+ feet between you and your Phantom.
  4. Kbboehm
    forgot to mention putting the S2 in Home Lock in NAZA. Il give it a shot and see what orientation it keeps. This thing is so cool...
  5. Mako79
    Sydney Australia
    Just make sure the GPS is activated on your FPV SmartPhone/Device and locked.
    And make sure the Radar ring is GREEN and NOT orange/yellow.
    Check the Ground station and make sure the H moves when your FPV device moves.
    It pings every 2 seconds. If it doesn't, then DHP will not work properly.
    And as stated, make sure you are 10m away from otherwise it will switch to course lock mode.
  6. crash1sttime
    Manchester UK
    It's a function that Kenargo is building into his DJI ultimate app at present, search the forum for his thread on it
  7. msinger
    Approved Vendor
    Harrisburg, PA (US)
    That only works on Android though :(
  8. Kev the Frog
    Norfolk, UK
    Welcome to "The Darkside"..... :twisted:
  9. lfaitas
    "And make sure the Radar ring is GREEN and NOT orange/yellow." how do you do that?? i use NAZA node and have an iphone and have enabled dynamic home point in vision app and i am more than 10m away from phantom but still nothing.. what am i missing?
  10. Mako79
    Sydney Australia
    Try this.
    Enable GPS and data on your phone.
    Start the DJI app and go into GS and download the maps.
    Once done your phone should have a fix.
    Now connect to the phantoms wifi and go through your normal launch sequence.
    Once launched, go further than 10m and switch to GS and see if your device is dynamically changing positions. The ring should now turn green.
Similar Threads - dynamic home point Forum Date
Inspire 2 dynamic home point feature! General Discussion Nov 22, 2017
Dynamic home point? Phantom 4 Discussion Jul 11, 2016
Dynamic homepoint? Phantom 4 Help May 18, 2016
Can the Phantom 4 use a Dynamic Home Point when Flying from Boat? Phantom 4 Discussion May 11, 2016
Dynamic home point Pro/Adv Discussion Apr 8, 2016
