and do you have gimbal problems with FW 1.8?Hello friends.
I went to lower and lower firmware (P3P) but after uploading 1.7 of 1.8 there are problems. Gimbal does not react, the message about the problem with the firmware makes it impossible to do anything. I had to go back to 1.8. Some solution ? Regards
if not, why do you want to downgrade?
this thread is quite old and some of the information is not true anymoreAnd why everyone here wants to lower the version to 1.7 ?(There is no problem in version 1.8) Regards
and what did you want to use after downgrading to 1.7.60?Can I get more information about dji-firmware-tools for P3P ? Regards
AFAIK there is no FCC mod for Phantoms, 32 channel hack onlyI want to switch WiFi to Fcc mode, and turn off the altitude limit 500m. Or maybe there is already ready compiled software with no limit on altitude and with FCC mode ?
Changing P3P from CE to FCC. Is it possible?And I will get some tips on how to do it?
Will I find help to turn off the altitude limit in the easiest way in DJi Phantom 3 Professional ?
Thank you for the information. RegardsThis thread is about downgrading.
Also, figuring out the software by yourself is more educational.
You need to extract firmware, edit flyc_param_infos and update them within flight controller module. Then flash that to your drone.
Try searching for retroroms dji wiki for details. Also there's nolimitdronez which lets you pay for having such things done automatically.
I won't mind if the thread will be cleaned of these unrelated posts.
binHello, my example China, I can't find the firmware of remote control 1.5.8. Who can send it to me, thank you. My mailbox is [email protected]
Curious about " the newer(cool way to do to, but not for any lamers that can't/don't want to study/read whole threads and directions) " . Got link?
hi have the same problem constant beep at the end let it go for a half hour longer still constant beep gave upI believe what ultimately fixed it for you wasn't the modules but the fact you let it update through all that loud beeping and didn't care about the possible overheating issue...I had the same issue once when i interrupted an update and the next time i tried to update i got the crazy loud ESC beeping continuously for maybe a 30min while in the background i could hear the very faint d-d-d which made me let it keep going...It was one of the most painful things i had to listen to and I wanted to stab my eardrums with an ice pick..So hats off to you for enduring this and being patient and happy to see your flying again bud!
Hey, did the log pass/fail text file say 'upgrading...' after you did this or did it say 'sucessfull'?Last week I rolled back successfully on my P3A from P3S_FW_V01.11.0020 to P3S_FW_V01.10.0090 with DEBUG file method. After downgrade all lights were red. So I turned it off/on and bird did the same SW update once again. After that it was O.K.
how to make file "P3X_FW_DEBUG" to force downgradeI rolled back from 1.11 to 1.7 too with debug method. Can confirm it is working for me. I'm having the board P01012.09 .
I did it like:
1.11 -> 1.10 + Debug
1.10 -> 1.9 + Debug
1.9 -> 1.8
1.8 -> 1.8 + Debug
1.8 -> 1.7
1.7 -> 1.7 + Debug
The last step was important for me, every version step was fine without a + except for 1.8 -> 1.7. There I had to use again debug method on 1.7 itself otherwise I got a + .
EDIT: I have to say that I did the update from 1.10 to 1.11 within the day the update was released the first time on 06.07.2017. And the downgrade was done within the next two days. I don't know whether DJI modified 1.11 to prevent downgrading. I attached the 1.11 I downloaded at 06:30PM at the release day and which I used to upgrade. LINK
