RTH
I’ve just bought a DJI 4 drone after crashing my old one, I am using the original controller the problem is when I command RTH the drone goes up to 120mtrs. The setting for avoiding trees is set at 40mtrs.
How can I change this?
Welcome to the forum!
"The setting for avoiding trees is set at 40mtrs."
Where do see this setting at?
"when I command RTH the drone goes up to 120mtrs."
How do you know it goes up to120mtrs?
Rod ..
Hi I use my mobile phone, the 40mtr setting is to clear the trees beside my garden and the 120mtrs is the maximum height setting. Someone suggested it might be something to do with the drone code? not sure he meant on that one.
The drone is a replacement for my original one it is “linked” ok
Not sure why it's overriding your 40m RTH setting but could the 40 meters be showing up as 120 feet on screen? If not, try clearing the cache or even delete then reinstall GO 4 then afterwards set a new RTH height in settings. If you find the solution let us know, could help others.
Reactions: captainmilehigh
Russianman92
