Does a Standard 3 fit is a Advanced/Professional case?
Hi
Does a Standard 3 fit is a Advanced/Professional case? If not what is the difference?
It will fit in some cases, but it won't fit in many cases because the remote controller is not the same size. Make sure the case you're buying is listed as being compatible with the P3S. You can find some compatible cases here.
So I could modify it to fit the controller. The bird will fit though? It is not taller or anything daft?
The bird is the same size.
Thank you case ordered
intertronixlabel
