DJI Video Downlink Flicker
I'm at the point that I'm considering buying a new video transmitter for $100 because I can't think of a solution. Anyone?
I couldn't really see from the video, but how is the camera set? There was a similar issue on here a few weeks back and it turned out that the camera was taking video and stills, causing the output of the camera to "mute" every time a still was taken. This gives a regular drop out.
Test: Turn the camera off and run with just the OSD and see if the picture is now more stable. If so, you know the link is not the issue, but a setting on the camera.
Its still a fairly consistant issue with the GoPro disconnected. At this point should I assume the video transmitter is bad and I should look into replacement or is there any last ditch effort I can try?
I called DJI but they want me to send in my Phantom 2 and transmitter for well over a month. At that point I'd rather just drop $100 and by a new transmitter.
Spend half that and buy an Immersion 600mW. This is probably the best regarded TX, while the DJi one is not that well thought of in some circles.
