Confused on FPV selection
O'Fallon, Missouri
GO has a gimbal selection for "follow" and "FPV."
"Follow" appears to be the default.
The owner's manual is not very specific on this.
When I research FPV in this forum, I always end up in areas of goggle discussion and such.
Is there any reason to select FPV using only a tablet?
What are the reasons to fly no-goggle FPV, if any?
And does FPV lock the gimbal and thus disable the gimbal adjustment dial?
I have not tried FPV for fear of not knowing more about it.
Thanks!
FPV is usually only used when flying with FPV goggles. This video shows the difference between FPV and Follow:
That's kind of what I suspected.
But I was thrown off by having a FPV select option, but no installed HMDI port (which I believe can be easily post-installed).
Just thought it would have been included.
I still use Follow when using FPV goggles/glasses. Most other people are too when they want to capture usable video/photos.
The HDMI Output Module can be easily installed on the remote controller in about 5 minutes. You can find detailed installation instructions here.
ODIN Reviews
