Compass error - restart aircraft
Hello, I've got a few flights under my belt since getting my Phantom a few days ago and love it.
Today prior to flying I did the I'M and gimbal calibration and already I saw it made a huge difference in stability (unless it was just less windy?).
I then did a compass calibration and went to do an auto take off. It then gave me an error which I couldn't properly see as another screen kept popping up in front of it almost immediately. I think the message said 'compass has failed, please restart the aircraft'. It seemed to calibrate OK though which was odd. I may be wrong as to the exact wording of it but it was along those lines.
So I restarted it, don't think I calibrated again and all was fine, managed to auto take off and didn't experience anything weird. Do I need to worry about the error, is it likely to occur again in anyone's experience or shall I just carry on as normal and stop being paranoid?
Thanks,
Rich
Sent from my SM-G900F using PhantomPilots mobile app
Yes, error messages may appear from time to time. so it's suggested to lift off and hover a couple minutes to check if things appear ok. warm up the battery and then take off
Sure..flying any pricey drone, be cautious, be normal.. ha
RedHotPoker
Reactions: Rich UK and Digdat0
I had something like that happen once. It's never happened again. It was on the second flight that I made with my P3P. I haven't changed a thing and it hasn't happened again. Mine was a compass failure.
Reactions: Rich UK
No need to warm up the battery .... not even when flying in the UK ;-)
You'll do well to take off to about 6 to 10ft, check the controls (fwd, back, left, right, yaw) let it hover for 30secs. Have a quick check of you battery cells and that no errors have popped up ..... and away you go
Reactions: Rich UK
Yeah no, only in Canada? Hahaha
RedHotPoker
Reactions: Numone
I always let it hover at my eye level for a few, just to be sure everything is rock steady, and to quickly check the MOD values/numbers.
Once it has been proven stable with no jitters or erratic movements, off we go...
Here's a quick list...
PFC, pre-flight checklist
  • Phantom & R/C battery charged
  • Tablet charged (reset or remove apps from memory)
  • Propellers installed and tightened
  • Remove gimbal lock
  • Gimbal not obstructed (grass)
  • Tablet volume & luminosity to MAX
  • Tablet « Do Not Disturb » Mode
  • Tablet to R/C cable attached
  • Tablet Wifi & BT OFF R/C ON
  • R/C in P-Mode
  • Phantom ON
  • Launch DJI Go app
Check values :
1. Compass status
2. IMU values (0, 1, 1400-1600)
3. Gain values
4. Max height
5. RTH height (depends on flight location)
6. R/C EXP & Gain (0,5-0,4-0,5)
7. VPS ON (if indoor flight)
8. Satellite status
9. Format SD card
10. Camera settings (LOG, video size, …)
11. Gimbal configuration (1, 2 or 3)
12. CHECK HOME POINT CHECK BATTERY STATUS (Cells)
Finally: Takeoff Hover 30 seconds & check stability
All systems are Go!! Hahaha
RedHotPoker
Reactions: Rich UK
  • R/C in P-Mode
  • Phantom ON
  • Launch DJI Go app
Check values :
1. Compass status
3. Gain values
4. Max height
8. Satellite status
9. Format SD card
RedHotPoker
Cool thanks mate, I've screenshotted that!
robvalduga
