Need feedback on Pro's and Con's of using Carbon Fiber Props instead of stock DJ I Props? I have watched some YouTube video's on them providing better stability but they are louder than stock Props.
Rubbish.I greatly favour the use of CF props over plastic. Below is a list of the pros and cons. Less vibrations give the operator great control over their unit.
Carbon Fibre Props or Plastic?
I would NOT follow this advice. As nearly EVERYONE ELSE has stated these drones are not made for CF props! CF props are designed for high performance things like 3d helicopters. You WANT the flex and give that plastic provides for smoother flights and more forgiving. It is a CAMERA drone after all....geez
Again ....this comes down to brand. I have had plastic props that were unbalanced out of the box. The CF DJI props that I use are always balanced straight out of the box....What brands have you used?Again. I don’t use them after 50% we’re out of balance out of the box!
Jim
WA5TEF
Stick with stock props because if you crash into a building or tree, a oem prop will break more easily than a carbon fibre prop and something got to give, probably a motor!
