Hey guys,
New here just got a used P3S from offerup, He said it just needed a FW update so i was like ok cool. Took charged everything up turned on the App and the Remote Control LED shows red and the Phantom Battery shows red but the link shows green and the App says Remote Controll signal weak with no status on the phantom no video feed and IMU shows nothing.
I'm still able to move the gimbal and turn on the motors but i still havent flown it.
So when i tried updating it to the latest FW 1.8 by loading it to the SDcard and only turning on the AC it would do it boot up and start upgrading but then it would fail. I've tried several times with no success and i've even put 1.7 and still nothing. I've also tried doing a force update by holding the link bottom as i turn on the phantom and it would do the same thing and still nothing.
Been trying to figure this out for a couple of days and reading through the forums to see if anyone has had issues and trying, so this is where i'm at now
Any help would be appreciated thanks
So this is everything thats on my FW results
Delete history success.
Result: Abort.
The current firmware does not support downgrade. Use a different version of firmware to downgrade the target version.
========== 2014.01.01 00:00:14 remo-con disconnect======
Packet: P3C_FW_V01.05.0070.bin
Result: Abort.
Result: Abort.
========== 2014.01.01 00:00:13 remo-con disconnect======
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Packet: P3C_FW_V01.08.0100.bin
Upgrading ...
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Abort.
Result: Abort.
========== 2014.01.01 00:03:20 remo-con disconnect======
Result: Abort.
Result: Abort.
Result: Failed.
Result: Failed.
Upgrading ...
Result: Failed.
Packet: P3C_FW_V01.07.0090.bin
Result: Failed.
Result: Failed.
Upgrading ...
Result: Failed.
Result: Abort.
Result: Abort.
Result: Failed.
Packet: P3C_FW_V01.04.0060.bin
Result: Abort.
Packet: P3C_FW_V01.03.0050.bin
Result: Abort.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Upgrading ...
Result: Failed.
Result: Abort.
Result: Abort.
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
Result: Failed.
Upgrading ...
Result: Failed.
Result: Failed.
Result: Abort.
Result: Abort.
Packet: P3C_FW_V01.06.0080.bin
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
Result: Failed.
Packet: P3C_FW_V01.07.0800.bin
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
