Can I use Phantom 4 Pro IMU and GPS-board on Phantom 4 Advanced ?
I have Phantom 4 Advanced which shows message "Navigation System Error" and "Check Redundancy State".
IMU and compass calibrated several times and tried with other controller.
No metal objects near the drone.
The drone does not find any satellites and in "sensors state" section there is texts "moving" sometimes on both of gyroscopes and accelerometers, but this can be that it takes some interference sometimes.
Compasses are green as it should be.
I think the GPS-board can be the reason, because IMU and GPS-boards are different on Phantom 4.
So, can I swap GPS-board straight from Phantom 4 Pro to the Phantom 4 Advanced ?
If the GPS-board replacement not working, I will try to swap working IMU-board from Phantom 4 Pro to Advanced, but can I do this ?
Thanks for answers !
Reactions: insanony00
I know the Pro and Adv use the same basic body shape (unlike the P4) so would assume they use the same gps components. Have your part # searches confirmed this? Personally I would give it a try.
I can confirm that the GPS-boards are same on each other Advanced and Pro-versions.
I replaced Phantom 4 Pro GPS to Phantom 4 Advanced and now the drone is working like it should.
For the future it would be interest to know if the Pro-version IMU is also compatible for example with Advanced.
I think Advanced and Phantom 4 Standard have different IMUs, so then I can not use the Pro-version IMU on the Standard version.
tom sauter
