Lugerc, you are NOT alone in this. I had the same thing happen to my P3P on Thursday the 12th, two days ago. I was a bit closer, was 800 some feet away from myself. I may have lost contact I think due to a cell tower antenna right next to where I was flying from, or possibly an overzealous seagull that didn't like me being in it's space. those bastards are territorial after all and I had irritated a few of them with my flying earlier in the six minute flight. I had mine set to return to home on the event of disconnect and have had it do as such previously, but not this time. I had full line of sight to the Phantom, looked down at my iPad to check my video framing when I saw the disconnect message and video freeze. I looked back up and I couldn't see it. It was early morning so still a little dim, but daylight. I did have the forward LED's turned off, had I had them on maybe it would have been easier to spot the Phantom. Regardless I was basically straight out from my position about 800 feet and one hundred feet up. I pulled back on the stick to fly it backward to me in case I still had some control, but after having done so for several seconds and seeing nothing. A few seconds after the disconnect the video came back for a brief second and then gone again, but in that brief second it appeared that it had been flying back towards me as I had been commanding. I kept trying with the back stick but it never reappeared in the sky nor reconnected. I even pressed the RTH button but it never came back. I took a screen cap of the last video image and the map which I will attach, as well as a shot I took from my vantage point of it's last known position in the sky. I searched the area where it showed as being last, but turned up nothing other than a dead pigeon which I don't think could take it out, nor did it seem chopped by props or anything. In my post disappearance search I noticed the video image frozen and the last known position are not matched, the frozen image has a view of the area where it showed as being on the map last.
