Just put a new gimbal on my p2v and it will not tilt...it just stays in the level postition. When I try calibrating it and open up the vision assistant I do not have an x1 box in the sticks section...just the x2....can anyone help me out please?
captej26 said:Do we have to guess what gimbal you have
Its a motorpixie 2 axis gimbal Geert....I do have values set per a tutorial found on youtube. My original gimbal still works fine...tried it yesterday. I cant make this gimbal work no matter what I try. Everything functions normal and properly except for the tilt function. Any ideas??Geert said:Hi Nick,
Which gimbal are you using?
Have you set some values in the Servo Travel Limit ?
Geert./.
nick231 said:Its a motorpixie 2 axis gimbal Geert....I do have values set per a tutorial found on youtube. My original gimbal still works fine...tried it yesterday. I cant make this gimbal work no matter what I try. Everything functions normal and properly except for the tilt function. Any ideas??Geert said:Hi Nick,
Geert./.
gunslinger said:nick231 said:Its a motorpixie 2 axis gimbal Geert....I do have values set per a tutorial found on youtube. My original gimbal still works fine...tried it yesterday. I cant make this gimbal work no matter what I try. Everything functions normal and properly except for the tilt function. Any ideas??Geert said:Hi Nick,
Geert./.
Just out of curiosity... Did you buy the MotorPixie on the classified section of this forum?
Thanks...
-slinger
nick231 said:Yep, this one was mine. I've been helping him troubleshoot the problem, but so far nothing has working, for whatever reason his app will not allow manual control of the pitch even though the gimbal appears to be operating properly. I'm out of ideas
I have given up....after 2 weeks and countless hours and dead ends I am basically marking this off as a loss...it was only 90 bucks plus all of my time...which is not the issue anyway. I guess I am the only one who might wonder how something worked just fine until I tried using it?? I cant and will not try selling it on the classifieds here or anywhere else because it is NOT a working unit. I will happily admit that the seller was cordial in helping me attempt to fix this unit....but I wasnt buying a unit that needed work. Now with all of the goofing around...my camera will not connect...so I have more problems then what I started with. Im not happy.
I will try that....should it respond while I am making the changes?AnselA said:In Assistant, if Servo travel limit / Pitch center value is changed will the camera move?
nick231 said:I will try that....should it respond while I am making the changes?AnselA said:In Assistant, if Servo travel limit / Pitch center value is changed will the camera move?
