I took my P4 for a flight and got Vision system error notification, right downward sensor fault.
I have been doing my best to troubleshoot, but I need some new ideas.
I have been trying to calibrate the sensors on the DJI assistant, the forward ones calibrate ok, but the downward ones are not detected. On the downward calibrate screen there is a small window on the left which shows the image from the cameras, and if I cover the left camera the small window goes dark, if I cover the right camera nothing happens, which leads to me to conclude that the RHS camera is indeed not working.
The firmware is up to date, the AC flies OK, I have never crashed or mishandled, where do I go next.
Should I remove the bottom cover plate and check seating of camera etc, any help or suggestions will be much appreciated.
For the record, I have tested with Litchi and with both IOS and android device and still the same fault.
I have of course cleaned the camera glass, it was not dirty anyway. Also refreshed the firmware.
Help
Help
