Video cutting out
Anyone ever have a problem with their video cutting out by itself after you press the record button? It will mostly do it when I try to shoot in 4K. 1080 60 FPS works ok. I’m using a sd ultra 32gig card. It has plenty of room on it. Doesn’t matter if the drone is close or far away. I don’t loose my display either. It just stops recording. I can press it again and it will start recording again, only to cut out a few seconds later. Weird
Sounds like your SD card is not fast enough. At 4k, there's a lot of data streaming to the card pdq.
So should I get an sd extreme. What's a descent one. I don't need a high capacity because I usually just download everything to my computer.
If you're talking about the SanDisk brand, from what I gather the extreme won't be fast enough either... better to go ahead and get the pro, and I think 32gb is the smallest in that line - plenty big enough. I'd rather have several smaller ones than one big one.
jorge sanchez
