Using Litchi I have No Gimbal Movement
I Have a P3s and have been using Litchi with no problems. Set a mission up using WayPoints / Focus POI (can see that Drone is pointing to the POI & Can see that the gimbal settings are changing as i change the Altitude of the POI. But when i run the mission the bird flies to the different WayPoints and rotates correctly but NO gimbal movements. (Note: at start up i see the gimbal go thru it's normal movements). In DJI Go App i have it set to "Follow". I can not figure out why this just started. (Note: No Crashes / No Firmware Updates since last flights)
Make sure you have POI selected in the mission settings and not just on the waypoint settings.
Reactions: Pharm
The AC must be in range of the RC for the gimbal to point at the POI. This is a restriction of the DJI SDK, not a Litchi issue. Annoying on long range missions that take the AC out of range, yes, but Litchi can't change it unless DJI allows it from within their SDK.
Is your SD card full? I have experienced the drone pointing it's cam down when the card gets full with the litchi app. Took me quite a few minutes to suss this one out one day... Don't know about DJI GO.
Thanks for the replies!
I ran 2 short missions this last Sunday and they both worked normally. ( I made no changes in DJI Go or Litchi and i had the two switches the same (Left up & Right down)
So i guess maybe i just had a bad upload of mission to the bird or a glitch somewhere.
Thanks again
Koen
Don carlos
