Meta4
Premium Pilot
- Joined
- Jan 8, 2014
- Messages
- 15,305
- Reaction score
- 9,247
It will - as long as you have enabled multi-flight modes in the app.So just a flick of the PAF switch and that's it, it'll change instantly?
It's disabled by default and because it's in the Phantom, you can't tell in the app unless you are connected.It hasn't been enabled at all since I got the P3...that's assuming that I can check that without being connected to the drone, but it's not showing as being enabled right now.
I'm still liking the theory that you had something below that confused the VPS.
I remember way back a guy crashed on his roof when VPS unsuccessfully tried to read his sloping roof.
That's the only thing I can think of that would activate the VPS.
It usually stays off if there's nothing less than 3 metres below it.
Lots of owners leave it disabled just to make sure they don't have that happen.
If you need a bit more confidence before you lift off, you can just leave it there with the props off, switched on and connected and watch the GPS indicator for a while to confirm it's stable.
The ground is your biggest obstacle. It scares me more than the trees do.I'd be quite confident with it just hovering about my height, I'm not scared of that altitude
I'd be quite confident with it just hovering about my height, I'm not scared of that altitude, it's when it goes high (10m and upwards) that I get nervous.
Altitude is your friend.
If you were higher than the trees, you would have easily missed them. When further away from obstacles, you'll have more time to react and correct the situation.Well, given mine got stuck in a tree, and then plummeted from quite a height to the ground, it's more frightening to hit the ground from high up than down low, no?
Stay a long way clear of trees.Well, given mine got stuck in a tree, and then plummeted from quite a height to the ground, it's more frightening to hit the ground from high up than down low, no?
It's easiest to use the radar at the bottom, left of the DJI GO app to follow the orientation. Your iPhone's compass should not lose calibration often. But, if it does not match the direction the radar is indicating, then you should recalibrate it.I've since learned that the front of it can be seen on your map with the narrower part of the red arrow...but then also you're apparently meant to make sure you calibrate your iPhone compass so they match...would that be right?
This is my idea of somewhere safe to fly. Nothing to hit and no interference.
VPS (Video Positioning System): uses a small camera underneath to help positioning of the AC relative to ground. Can (must) be switched ON or OFF. If ON, it kicks in at 3m to aid in flying in some situations.
GPS: provided there is enough satellites around, the P3 is always receiving signal. You can use (GPS) or not (ATTI) to fly. RTH is autonomous i.e. it'll work in any mode provided there is enough satellite count AND your HOMEPOINT has been set prior to takeoff. If you're in GPS mode, it'll lock on position (horizontal and vertical) whenever you leave the sticks, regardless of wind or any other interference. It will BRAKE, stable and in total control the instant you flick the switch.
If your P3 is VPS OFF and GPS OFF it'll move around horizontally AND vertically. If you enable VPS the system will kick in at 3m to keep it vertically stable up to some point, but as said above by moderators it can interfere with flying in some ways depending on what's bellow it. My P3's VPS is OFF all the time, I takeoff/land visually regardless of the mode I'm in. And I never use CSC to land, ever.
