- Joined
- Jun 25, 2014
- Messages
- 37
- Reaction score
- 0
@Gary ph2 Thank you so much for your tips, i took a look at the props and they do have some wear, but not a significant chip, and the edges look Ok. I have brand new ones so when i get the time this week i will fly agein after i work on some of the tips i got from you guys, including brand new original @Props.
@Mako79 , thanks, i did an advance calibration and everything its Ok, i been flying this quad for more then 10 month without a problem, always using the same equipment on it ..... the wired thing is that the descent happen only when gimbal/gopro are on .... if i remember well, at last, i did try and made to fly a hole batt without the issue, and when i loaded ... bummmmm Still, just to make sure, i will test fly agein, first without gimbal/gopro and after with it ....... just to be sure of the info the im giving to you, becouse that will be a good indicator of wich way we need to look at i belive .....
Cheers guys you are really kind with all your tips and help, i really need to fly agein, and becouse im in Mexico, caribean side, it is really hard to find a repleacment over here So if i can fix it by myself with all your help, will be really good !!
Cheers guys !
Cheers guys !
