This is gonna be fun! (Distance tests)
The long range kit for p4 looks no different than the V-2 , but the FPVLR Standard kit runs BOTH 2.4 in a LHCP pattern
This is the Terminator and we'll start the test off UNBOOSTED.
Dropbox - terminator with p3s
Holy huge!..hows the weight? Does the 5.8 clear over the top of it pretty good?
. **EDIT
900grams (i've read this, I haven't weighed my own )compared to the typical DBS panels at 230g!
As you can see I have it flipped upside down so it allows the 5.8 cannon to run over the top
And these are 2x14dBi panels?
I found some 21dBi panels on ebay for a good price...if those terminator panels do well let us know. Man i hope u get some good weather!! I wanna see some numbers
Link please! I need A "procharge cannon" this Terminator makes the 15 turn look tiny
The panels are 2.4 tho. Im tryn to find a 5.8 high dbi panel
I have 4 coils all made..waiting for the copper clad pcb and pcb sma connectors..making you a 21 turn!!! What would be a good name? I was thinkin of "sniper" with a cross hair scope next to it or "take aim" with a cross hair. As soon as i get the rest of the pieces and solder it all up , it going in the mail!
According to this the 21 turn should be 19dBi...as long as i get everything just right
590 grams compared to the typical DBS panels at 230g!
You sure about the weight db? I weighed it at 890g...
Reactions: dirtybum
No, thats a # I read! I'll check it later and edit if needed, or have you weighed yours?
I tried that terminator on the pro, and from everything I seen with that, it's looking very promising for the standards Wi-Fi. Maybe weather will break later and I can do a lunch break run with the p3s
You guna try with amps or first see what it can do without
I went 40,000 at 200 feet high on the PIII pro unboosted! So I will definetly be trying the standard out, UNboosted terminator for wi-fi at first! But I think I'll go with the 15 turn BOOSTED for control! And the reason is, if that terminator is so badass that I can get out 30 to 40,000 feet unboosted then I dont want the control signal to be an issue,so as to give the terminator a fair test and see just how far it can go unboosted
Reactions: Mark The Droner
hcashmore11
