- Joined
- Sep 7, 2016
- Messages
- 33
- Reaction score
- 23
- Age
- 64
Hello All,
I know the stress cracks in the Phantom 3 Advanced aren’t a new topic but I think I’m the first to have this happen.
After discovering stress cracks both on the bottom and top shells I opened her up and I was shocked to see what I found! Not only multiple micro cracks but two of the ‘metal’ bases that the eight inner screws attach to came completely separated from the top shell!
This is beyond stress cracks; this is “Stress Crap”! Every one of the eight metallic screw bases has multiple micro cracks surrounding them. And as I said two of them completely separated from the top shell. Fortunately I have them both and some micro pieces of plastic to do a home repair.
No way is this going back to DJI in spite of their reputation for “excellent customer service” (sarcasm)! But from what I have read here it seems that all their replacement shells have the same flaw and most likely will eventually crack as well.
I wanted to thank everyone here for repair recommendations already posted. With that information I plan on a three pronged approach to the stress crack problem.
For all the “micro” cracks I’m going with the Weld On 4, with its needle like applicator and water like consistency it should sink into the micro cracks and seal them up. My second repair/prevention will be an application of Plast Aid to strength all the area’s that I can safely coat without messing up the motor mounts. And lastly my third treatment will be a coating of “Light” Hangar 9 fiberglass cloth on the outside of the top and bottom arms. I am going to extend the cloth covering up the vent areas.
(check update below don't use Eze-Kote!)
I may use a two part epoxy for the cloth but I have a resin based, water soluble produced called Eze-Kote that I would like to mention. I think it will be lighter than epoxy but I have to test and see how it bonds to this “f-upped” plastic. Eze-Kote is made by Deluxe Materials. It is really made to cover foam and balsa planes but I have used it on large r/c boats too. Once it is dry it is water and fuel proof, it also dries in 20 minutes, can be sanded and take paint.
I have no vested interest and do not make any money from this product. I only post a link so people can check it out. This is a UK web site but you can get this in the USA:
Eze Kote - Deluxe Materials
My P3A was purchased January of 2016…no bad crashes…no bad landings…just bad plastic!
Steve
Steve
